transducer location ??? |
anthonylizardi
Gold Member Joined: July-25-2007 Location: DFW, TX, USA Status: Offline Points: 836 |
Posted: December-12-2008 at 1:49pm |
Chris is right. I have been reading about this and Keith has a review on Humming Bird depth finder and that is the location he describes where to put the transponder. |
79nautique
another good spot is just in front and to the side of the raw water pumps thru-hull pick towards the rear of the motor.
Morfoot
I've heard of guy's doing that with great results. I'd use epoxy to bond the transducer to the hull and be sure to slightly move it around to remove any and all air bubbles and to ensure the epoxy spreads evenly over the surface area. I placed mine under the oil pan just aft of the drain plug.
xjglen
Groupie Joined: August-02-2008 Location: Canada Status: Offline Points: 62 |
I bought a 92 196 last summer, and was never happy with the performance of the depth sounder. During my time cleaning in the last few weeks I took a closer look at the transducer and discovered that it was mounted using silicone, and it looked as though there were voids. I guess the first question is should it be mounted with silicone?? I've always understood it should be mounted with (bubble free) epoxy. Second-where should it be mounted? Has anybody heard of placing the transducer in a bag full of water and trying it in different locations to find a good position?
93 Ski Nautique
