  New Posts New Posts RSS Feed - 1988 Martinique help
Rglover View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rglover Quote  Post ReplyReply Direct Link To This Post Topic: 1988 Martinique help
    Posted: February-25-2009 at 11:50pm
Viviationm,
Sorry I am just now getting back to you. I actually forgot and was just sitting in the boat wishing it was warmer and remembered I was supposed to send you a pic. You don't have to do that in Bermuda though do you? Anyway, here's the pic. In case you have trouble reading it the order from left to right is: PUMP/AUTO, PUMP/MANUAL, NAV LIGHTS, ANCHOR, ACC., IGNITION, BLOWER.
Let me know if I can help with anything else. I wish I was there to take that initial voyage with you that I read about on your other post. GOOD LUCK!!
vaviationm View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote vaviationm Quote  Post ReplyReply Direct Link To This Post Posted: February-18-2009 at 10:00pm
Thanks, the order of the switches would be great. Nothing seems to work right now, except for the ignition switch. So the battle begins!
From what I have found, it looks like the Ski Nautique's have a different instrument cluster and switch panel. Is this reflected in the wiring or just cosmetically?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rglover Quote  Post ReplyReply Direct Link To This Post Posted: February-18-2009 at 6:38pm
The switch labels are accessory, auto pump, pump, ignition (I think), blower, anchor lights and navigation lights. Right now the exact order escapes me but I will try to remember to look when I get home.
There are several postings on the site and in the reference section that have wiring diagrams. I am pretty sure that if you find one for a Ski Nautique of the same year model it will match the Martinique. At least that is what I have found for my 86 Martinique.
Let me know if I can be of help in any other way.
Post Options Post Options   Thanks (0) Thanks(0)   Quote vaviationm Quote  Post ReplyReply Direct Link To This Post Posted: February-17-2009 at 6:40pm
Recently bought a 1988 Martinique, but needs a little work before I can enjoy it. The labels of the push-button switch panel are worn off. What should be the label/function of each switch? Also, any sort of wiring diagram for the hull would be great. Mine stays overboard in salt water, so I have some additional challenges. Any suggestions to that extent are welcome too.
