HEI distr. convert for 351 |
Kristof
Grand Poobah Joined: October-08-2007 Location: Bree, Belgium Status: Offline Points: 3397 |
Posted: February-24-2009 at 9:37am |
That's not too far away. Good to see another member from this part of the world. A few more and we can start thinking about a first european reunion Just post some pictures of your boat, cause we're all hooked on pictures here |
Bart
Newbie Joined: February-23-2009 Location: Netherlands Status: Offline Points: 7 |
oke thanks guys!!
I understand now that i need too buy a marine distr. which one do you recommend? |
ski nautique engine 351W Building year 1990
79nautique
marine distributors do not use a vaccum advance mechanism like a car does. Also there are special screens that go in the vents so that if fuel vapors gets under the cap and ignites the screens prevent the flame from exiting the inside of the distributor. Also most have a conformal coating to prevent corrosion.
Also most older CC's use a reverse rotation engine that requires a different gear on the distributor that you will not find on a automotive versions. |
Bart
thanks guys!
can you tell me what the differents between a marine distr. and a car distr.? hee kristof im living near rotterdam. |
Kristof
Welcome to the site Bart!
Where exactly are you from in the Netherlands? |
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21169 |
Doc, I think I remember reading here that you can run a 351C/460 dizzy on the 351w if you change the drive gear. Is that what youre saying? Theres a good chance his '91 is a LH, btw.
Bart, you'll want to be sure to use a marine distributor regardless of which route you take. |
boat dr
Right dizzy but wrong motor....
You have a 351 W, I would suggest a Mallory Uni-Lite or E-Spark for a 351w normal rotation, aka car motor, remove the drive gear from the dizzy you have now and simply replace it. Same dizzy just different drive gears.................Boat dr |
Bart
Hello people
I have a question. I want to buy a HEI distributor too convert my engine, this one we can buy in the netherlands, Ford 351C/460, 50,000 Volt by Wysco. Is this a good product for this engine? Thank you Best regard Bart |
