  New Posts New Posts RSS Feed - Cold Start
Cold Start
79nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Topic: Cold Start
    Posted: April-20-2009 at 1:31pm
choke needs adjusted a little and the carb tweek a shade to get exactly right so all you have to do is hit the key amd listen to it purr.
GottaSki View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GottaSki Quote  Post ReplyReply Direct Link To This Post Posted: April-19-2009 at 11:29pm
Pretty standard operating procedure for a carbed engine, no?
River Rat to Mole
mndanielsncsu View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mndanielsncsu Quote  Post ReplyReply Direct Link To This Post Posted: April-19-2009 at 11:15pm
I tried to search this topic before posting, but the search function hasn't worked for me for the last 2 days.
I have a '93 Sport with the Pro-Boss. Whenever I try to start the boat for the first time, I always have to pump the throttle 2 times before it will fire up. Never seem to have any issues once it has warmed up. What typically causes this? What are the easy fixes to try to solve it?
I recently tuned everything up and was hoping that it would help this, but no luck. I changed spark plugs and wires, fuel/water separator, and set the timing to 18 BTDC at idle (done with the knock sensor unhooked). Best I can tell, the timing is pretty darn close to 18 BTDC.
Not sure if the carb was ever rebuilt.
