  New Posts New Posts RSS Feed - UK’s 78 SN
UK’s 78 SN
 Post Reply Post Reply Page   123 8>
uk1979 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote uk1979 Quote  Post ReplyReply Direct Link To This Post Topic: UK’s 78 SN
    Posted: March-30-2018 at 5:36am
As said this would not work for 2001 boats ...if you think yours may be mush inside once you have taken the floor out leaving the stringers have a some rolls of thick wall lining paper used in home decorating you can unroll and cut to the shape of the hull and draw along the top stringers ( do the face that facing the centre of the boat as that should be the tallest ) remember you will need to take the thickness of the old glass off the height on your new stringers .... my guess it will be 1/4 inch , as you remove just mark up you templates you have made . Thinking about it you may find your template may be about right in height as you would be marking the template off the hull with the stringer glass on it, you will have to judge for your self on the factory glassing down the stringer.
If you make a good job of this I'm sure someone on the site would copy them into Cad to help others .
Good luck with the build.
Happy Easter Guys.
Roger.
Lets have a go
56 Starflite
77 SN
78 SN
80 BFN
jterr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jterr Quote  Post ReplyReply Direct Link To This Post Posted: March-29-2018 at 5:15pm
Originally posted by uk1979 uk1979 wrote:
Did these a year or so ago, may be of help to others and could help keep the average age of boats here down
Sorry but sizes are mm
Sizes taken off my old stringers at the wide side of each,always check your ones are the same if you use the above drawings on your project.
Have Cad file if you need to print full size for template.
Would these work on a 1983 SN??
Post Options Post Options   Thanks (0) Thanks(0)   Quote uk1979 Quote  Post ReplyReply Direct Link To This Post Posted: April-17-2012 at 5:10pm
Originally posted by 65 'cuda 65 'cuda wrote:
110 octane or aviation gas? That should pull pretty well!
Gary, sorry for slow reply been off on a Easter Break , I am trying to run her on our super gas if I can keep the running temps down as much as possible.
Are you (You are) building a new doghouse!!!!?
I’m hoping to be able to mod the old as I have spare height now with the 1.23 tranny much the same as Joe and Tim have.
Cheers Roger.
Lets have a go
56 Starflite
77 SN
78 SN
80 BFN
65 'cuda View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 65 'cuda Quote  Post ReplyReply Direct Link To This Post Posted: April-07-2012 at 2:02pm
SNobsessed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: April-07-2012 at 12:39am
Roger - Pretty amazing stuff you have there. Can't wait to watch the video of your hole shot once you get it running!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 65 'cuda Quote  Post ReplyReply Direct Link To This Post Posted: April-06-2012 at 10:44pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote uk1979 Quote  Post ReplyReply Direct Link To This Post Posted: April-05-2012 at 9:27am
Originally posted by Ben#155 Ben#155 wrote:
Cool! will you use two of these big turbo chagers? how will you control the boost pressure?
Ben, Yes I will be running twin turbos,and boost pressure controlled by valves/wastegates along with it all hooked up to the engine management system.
Roger,
Very Nice! Are going to plumb up the exhaust yourself? Dry runners into a collector to the turbo then to the wet exhaust(lots of heat) or jacketed runners to the turbo, (Less heat, but less energy for the turbine)?
Pressurised airbox through a carb or EFI? How much boost are you aiming for? Initial compression ratio? Inquiring minds would like to know!
Gary, I'm making up some jacketed log stile manifolds keeping them as short as possible into the turbos,I'm just not keen on dry runners under the dog house.
Engine spec as follows......
SBC 383 running around 9 to 1 comp, keeping on the high side to help response and reduce lag at low rpm.
I am going with water cooled intercoolers.
Full sequential EFI by a programmable engine management system (had to wait a long time to get my hands on one)new out the box are just to much $$
Shooting for 12 to 15 psi boost and then work from there.
Lets have a go
56 Starflite
77 SN
78 SN
80 BFN
Post Options Post Options   Thanks (0) Thanks(0)   Quote 65 'cuda Quote  Post ReplyReply Direct Link To This Post Posted: April-04-2012 at 11:15pm
Roger,
Ben#155 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ben#155 Quote  Post ReplyReply Direct Link To This Post Posted: April-04-2012 at 8:47pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote uk1979 Quote  Post ReplyReply Direct Link To This Post Posted: March-19-2012 at 12:15pm
Originally posted by 79TiqueRebuild 79TiqueRebuild wrote:
Roger ,
Just think of what you could achieve if you could have easy access to the parts and materials you want!!
Too cool Monty
Thanks Monty.....I have a long list of stuff you guys have which is not available here shall keep looking out for stuff or ways round the problems
Lets have a go
56 Starflite
77 SN
78 SN
80 BFN
Post Options Post Options   Thanks (0) Thanks(0)   Quote uk1979 Quote  Post ReplyReply Direct Link To This Post Posted: March-19-2012 at 12:09pm
Originally posted by HatterBee HatterBee wrote:
Now this is cool stuff...very innovative.
Thanks Allen...Keep up the great work on the 77 gotta keep the gen 2 SN numbers up
Lets have a go
56 Starflite
77 SN
78 SN
80 BFN
Post Options Post Options   Thanks (0) Thanks(0)   Quote uk1979 Quote  Post ReplyReply Direct Link To This Post Posted: March-19-2012 at 12:04pm
Originally posted by Keeganino Keeganino wrote:
Roger can I be you apprentice? Cool stuff!
Keegan....next time your over pop by and if your on one of the Harley's you work with how cool would that be I think you need to open a shop up in the UK.
Lets have a go
56 Starflite
77 SN
78 SN
80 BFN
Post Options Post Options   Thanks (0) Thanks(0)   Quote uk1979 Quote  Post ReplyReply Direct Link To This Post Posted: March-19-2012 at 11:57am
Roger,
Your mind is always working! Fantastic that your engineering skills go along with it. Keep us posted.
Thanks Pete...will do the hard part is yet to come getting it to all run together
Lets have a go
56 Starflite
77 SN
78 SN
80 BFN
79TiqueRebuild View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79TiqueRebuild Quote  Post ReplyReply Direct Link To This Post Posted: March-17-2012 at 1:08am
Roger ,
Too cool Monty
HatterBee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HatterBee Quote  Post ReplyReply Direct Link To This Post Posted: March-16-2012 at 11:57pm
1977 Ski Nautique
Under Re-construction
My Rebuild Thread
Keeganino View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keeganino Quote  Post ReplyReply Direct Link To This Post Posted: March-16-2012 at 11:21pm
1973 Skier
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: March-16-2012 at 9:48pm
Roger,
uk 1979 part2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote uk 1979 part2 Quote  Post ReplyReply Direct Link To This Post Posted: March-16-2012 at 8:40pm
As you can see I have some old marine diesel turbos I have been playing with this how I have converted them to run off a Gas engine.
These are Volvo Penta units AKA kkk K27 turbos now part of Borgwarner trying to get OEM parts over here is not good.......just been given the run around by the official turbo suppliers ...... only happy to sell me a new one to change over......not good in the UK ... a lot of KoolAid around..... these turbos are a hybrid made by kkk using K27 turbines housings with a K29 fast spool compressor housing......yet to find boost maps for this combo.
Been collecting marine turbos for a while now it seems the Volvo Penta come up more here in the UK but my guess is most makes will change over with a little work......I managed to find an unofficial turbo parts supplier and rebuilt the turbos like this.
Your see the 3 turbine housings are all the same AR/size of flow but the one at the back has only 6 bolt clamping where the other 2 have 8 same part number just has cast #2 where the 6 bolt has #3 if you find this one life is good as it is a straight swap for the turbo shaft housing otherwise you will need to turn the flange off and turn down 1mm then turn the clamp ring on the housing.......all the other parameters are the same.
The turbine are the same size as a 911 turbo (sounds cool but they fit hundreds different engines) the hardest part to find is the compressor back plate.......no help from dealers and only have one so as it’s a flat shall make one this is my first test in Mdf before I run it out of the engineering grade Ali
First fit up.........all good now needs to be sent off for balancing
lets have a go 2
Post Options Post Options   Thanks (0) Thanks(0)   Quote uk 1979 part2 Quote  Post ReplyReply Direct Link To This Post Posted: March-02-2012 at 4:46pm
Originally posted by Boat Nurse Boat Nurse wrote:
Ditto Pete, Roger, have we made final plans yet... Boat dr
Billy, I will be at SJRR 2012 will call you with my travel plans.
lets have a go 2
Post Options Post Options   Thanks (0) Thanks(0)   Quote uk 1979 part2 Quote  Post ReplyReply Direct Link To This Post Posted: March-02-2012 at 4:41pm
Originally posted by nautique78 nautique78 wrote:
Im interested to see pictures of your project after you have completed it. Will you post some current pictures of the boat soon?
Roger may not. I think he's shifted over to wood hulls!!! As long as he doesn't try to put some MDF in it, I think he'll be OK!!
Roger,
You know I will never stop poking you about that non wood "substitute" IE MDF!! BUT, you are doing fantastic projects with it! I envy your skills.
Thanks Pete, I'm only using Mdf for formers But I have been tempted to try    there is a water proof one
lets have a go 2
Post Options Post Options   Thanks (0) Thanks(0)   Quote uk 1979 part2 Quote  Post ReplyReply Direct Link To This Post Posted: March-02-2012 at 4:32pm
Will do just been waiting for the temp to rise here so I can do the final part I have planed.
Been working on the engine and other parts
lets have a go 2
Boat Nurse View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boat Nurse Quote  Post ReplyReply Direct Link To This Post Posted: March-01-2012 at 11:46pm
The Boat Nurse
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: March-01-2012 at 9:01pm
Roger,
nautique78 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nautique78 Quote  Post ReplyReply Direct Link To This Post Posted: March-01-2012 at 8:25pm
nautique78
56Hot Rod Special
70Mustang
70Skier
76Tique
78Nautique
79Nautique
92Nautique
98Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote uk1979 Quote  Post ReplyReply Direct Link To This Post Posted: January-25-2012 at 2:49pm
Hi Jose, have your mail and sent the files,please read as many of the stringer rebuilds as you can and build up a plan that suits you,lots of great tips on here to make it all go well.
Please start a thread of the build to help others and any tips you find along the way.
Thanks for saving another 70' SN
Roger.
Lets have a go
56 Starflite
77 SN
78 SN
80 BFN
josemcordero View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote josemcordero Quote  Post ReplyReply Direct Link To This Post Posted: January-25-2012 at 1:25am
Hey roger
It Jose Cordero I sent you the message on the cad drawings my email is josemcordero@gmail.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote uk1979 Quote  Post ReplyReply Direct Link To This Post Posted: December-08-2011 at 7:47am
Originally posted by MattB MattB wrote:
Amazing thread Roger.
I might need to head down south to Hemel one day to pickup some new skills or just marvel at the work you have completed. I absolutely love the carbon fiber look to the cradle, absolutely amazing.
Threads like this just confirm that this is the right forum to be on. Keep the great stuff coming.
Thanks Matt,all the info you need is here on this site to keep that sharp looking boat of yours tip top for some of us fooling around with these US icons help you relax
Enjoy the site and the great knowledge on it along with the members
Lets have a go
56 Starflite
77 SN
78 SN
80 BFN
MattB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MattB Quote  Post ReplyReply Direct Link To This Post Posted: December-07-2011 at 10:20am
Post Options Post Options   Thanks (0) Thanks(0)   Quote uk1979 Quote  Post ReplyReply Direct Link To This Post Posted: November-29-2011 at 8:17am
Kristof don't forget all this stuff is down to Belgium Beer power
I hope your beer travels with you
Lets have a go
56 Starflite
77 SN
78 SN
80 BFN
Kristof View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kristof Quote  Post ReplyReply Direct Link To This Post Posted: November-29-2011 at 6:24am
It's real fun to watch all the stuff you come up with Roger!
I really need to plan a trip acroos the Channel to come see it in person...
- Money doesn't make one happy, but when it rains cats and dogs, it's still better to cry in a Porsche than on a bicycle...
