  New Posts New Posts RSS Feed - Front Cover Seal
Front Cover Seal
Siveck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Siveck Quote  Post ReplyReply Direct Link To This Post Topic: Front Cover Seal
    Posted: April-04-2005 at 1:10pm
Thanks everyone. I just compared the automotive seal and the special marine reverse rotation seal and the little flutes are oriented in the same direction.
nates78ski View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nates78ski Quote  Post ReplyReply Direct Link To This Post Posted: April-01-2005 at 8:17pm
You cannot install a speedi-sleeve on the rear cranl seal area witha 2 piece rear main seal because of the flywheel flange
Nathan
My '78 Ski Nautique
<a href="http://photobucket.com/Nates78ski" rel="nofoll
Jim View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Quote  Post ReplyReply Direct Link To This Post Posted: April-01-2005 at 11:54am
Speedi-Sleeves are suppose to work great on a harmonic balancer and 1 piece seal crank; however, I have been told that they WILL NOT work on the rear crank of a 2-piece seal?
Is this the case?
Post Options Post Options   Thanks (0) Thanks(0)   Quote nates78ski Quote  Post ReplyReply Direct Link To This Post Posted: April-01-2005 at 8:54am
A reverse rotation seal on the timing cover makes no sense. I've done marine work for years and all the seals are the same(good brand). A speedi-sleeve is a good solution to a grooved harmonic balancer. The rear main seal are the same just the knurling in on the crank is different or ommitted.
Nathan
My '78 Ski Nautique
Stan C View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan C Quote  Post ReplyReply Direct Link To This Post Posted: April-01-2005 at 3:27am
Siveck
I recently rebuilt my 78 351W and the balancer was rusted and pitted badly. I installed a seal saver sleeve an used a regular automotive seal. it doesnt leak a drop. Hope this helps.
Stan C.
Stan C
Post Options Post Options   Thanks (0) Thanks(0)   Quote Siveck Quote  Post ReplyReply Direct Link To This Post Posted: April-01-2005 at 1:47am
I'm rebuilding the engine in my '75 Nautique with the reverse rotation 351W. I have the special reverse rotation seal from Skidim for the timing cover. The problem is that someone has installed a sleeve and seal kit. The sleeve is on the harmonic balancer. Is there a reverse rotation sleeve and seal kit available? I guess that the seal for this kit would have a slightly larger opening. I'm guessing that the harmonic balancer might not be smooth under that thin sleeve. Maybe the seal that I have will work? Any thoughts or experiences with this? Thanks
