  New Posts New Posts RSS Feed - Look mom no wood
Look mom no wood
hasbeenskier View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hasbeenskier Quote  Post ReplyReply Direct Link To This Post Topic: Look mom no wood
    Posted: June-17-2009 at 12:03am
Chuck, Sorry for the delay in responding. The bulkheads are laminated on both sides with a layer of 1808 and a layer sandwiched in the middle. Susequently, they are layed up with one layer of 1808.Finally, the compartments will all be filled with foam.
bj
hasbeenskier
kapla View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: June-16-2009 at 8:23pm
Originally posted by gun-driver gun-driver wrote:
The side ribs is how I'm doing mine to eliminate the use of foam.
I am just using wood though. Great work.
Same on my resto...
<a href="">1992 ski nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote gun-driver Quote  Post ReplyReply Direct Link To This Post Posted: June-16-2009 at 12:32pm
Chuck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chuck Quote  Post ReplyReply Direct Link To This Post Posted: June-16-2009 at 3:36am
Cool. A monocoque Natique!!!When you taped the bulkheads to the hull, did you tape them twice (once in each direction?).
Post Options Post Options   Thanks (0) Thanks(0)   Quote hasbeenskier Quote  Post ReplyReply Direct Link To This Post Posted: June-15-2009 at 1:59pm
Chuck, just another note is this. Although it won't all get used, When I started this project I bought a 55 gal. drum of polyester resin, A roll of 1.5 ounce mat that weighed about 95 pounds and a roll of 1808 that weighed 179 pounds and 7 gallons of gel coat. That is a lot of weight. Having said all that an empty hull weighs near nothing.
bj
hasbeenskier
Post Options Post Options   Thanks (0) Thanks(0)   Quote hasbeenskier Quote  Post ReplyReply Direct Link To This Post Posted: June-15-2009 at 1:35pm
Hey Chuck, It has been a long time, Thanks for the interest. And I am not 100% sure but in the end it come out close to same.
The foam sheets and nidacore are very light in weight but they are laminated with mat and 1808. I have laid up additional glass in the bottom of the hull and I laid up the main stringers in one skin and six times in 1808. It is over built and unbelievably strong. In am very pleased with the materials and process.
What I know for sure is how the Ski Nautique already completed displaces water when sitting next to other 81's and that is the same.
hasbeenskier
The Lake View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote The Lake Quote  Post ReplyReply Direct Link To This Post Posted: June-15-2009 at 12:58pm
BJ, it looks great! Curious as to the weight . . . more than or less than wood and fiberglass?
Chuck
Walk on Water
www.coldwater.me
69 Ski Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote hasbeenskier Quote  Post ReplyReply Direct Link To This Post Posted: June-12-2009 at 11:41pm
The composite material used:
Main stringers laminated Divinycell H80 5/8" 5lb density.
Secondary stringers and bulkheads laminated polyurethane foam sheets 1/4" 10lb density
Deck pieces laminated nidacore 5/8"
hasbeenskier
Post Options Post Options   Thanks (0) Thanks(0)   Quote hasbeenskier Quote  Post ReplyReply Direct Link To This Post Posted: June-12-2009 at 11:31pm
Hey guys,
Thanks for the kind words of bar raising talent, and however true, it is not my own. The masterful work you see is that of the "Wizard". He is the force behind my restoration projects. I am a gorilla grinding hack and I do what he tells me to do. I have been privileged to stand in his shadows the last four to five years and learn a little. It is impossible adequately to describe his abilities, even the pictures don't do justice.
bj
hasbeenskier
uk1979 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote uk1979 Quote  Post ReplyReply Direct Link To This Post Posted: June-12-2009 at 5:25pm
Hasbeen great work on the none wood BFN.
Lets have a go
56 Starflite
77 SN
78 SN
80 BFN
BuffaloBFN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuffaloBFN Quote  Post ReplyReply Direct Link To This Post Posted: June-11-2009 at 5:49pm
Pete got bingo! I got a good description of how he does this bar raising work, but I'm clearly not worthy to speak for him.
1988 BFN-sold
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-11-2009 at 5:36pm
Originally posted by BuffaloBFN BuffaloBFN wrote:
Yall should see the boat he brought to the river...he's got talent!
I agree looking at this project. It's intriguing!
Originally posted by critter critter wrote:
Where did you get the floor panels ?
I have not seen them at Lowes...
Looks great..
Looks like B.J. made his own forms and laid up glass floor panels!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuffaloBFN Quote  Post ReplyReply Direct Link To This Post Posted: June-11-2009 at 4:12pm
1988 BFN-sold
Jim_In_Houston View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim_In_Houston Quote  Post ReplyReply Direct Link To This Post Posted: June-11-2009 at 4:06pm
I am blown away and impressed. The bar keeps getting higher and higher. I logged in to crack a simple joke but after looking at the pics I cannot bring myself to do it. Very nice work.
quinner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote quinner Quote  Post ReplyReply Direct Link To This Post Posted: June-11-2009 at 3:35pm
Originally posted by Luchog Luchog wrote:
what are you using instead wood????
Was wondering the same thing as Lucho.
fastjohnny View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fastjohnny Quote  Post ReplyReply Direct Link To This Post Posted: June-11-2009 at 12:04pm
I see no pics?
Luchog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Luchog Quote  Post ReplyReply Direct Link To This Post Posted: June-10-2009 at 11:21pm
critter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote critter Quote  Post ReplyReply Direct Link To This Post Posted: June-10-2009 at 11:19pm
Looks great..
1980 Ski Nautique
1966 Barracuda
SNobsessed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Posted: June-10-2009 at 10:49pm
The bar gets raised once again!
Post Options Post Options   Thanks (0) Thanks(0)   Quote hasbeenskier Quote  Post ReplyReply Direct Link To This Post Posted: June-10-2009 at 8:10pm
hasbeenskier
Post Options Post Options   Thanks (0) Thanks(0)   Quote hasbeenskier Quote  Post ReplyReply Direct Link To This Post Posted: June-10-2009 at 8:05pm
hasbeenskier
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuffaloBFN Quote  Post ReplyReply Direct Link To This Post Posted: June-10-2009 at 8:04pm
Except for the blue thing under the bow, I recognize a lot. That's top notch!!!
1988 BFN-sold
Post Options Post Options   Thanks (0) Thanks(0)   Quote hasbeenskier Quote  Post ReplyReply Direct Link To This Post Posted: June-10-2009 at 8:04pm
hasbeenskier
Post Options Post Options   Thanks (0) Thanks(0)   Quote hasbeenskier Quote  Post ReplyReply Direct Link To This Post Posted: June-10-2009 at 8:02pm
hasbeenskier
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuffaloBFN Quote  Post ReplyReply Direct Link To This Post Posted: June-10-2009 at 8:01pm
WOW!!!
1988 BFN-sold
Post Options Post Options   Thanks (0) Thanks(0)   Quote hasbeenskier Quote  Post ReplyReply Direct Link To This Post Posted: June-10-2009 at 8:01pm
Photo bucket threw me a curve
hasbeenskier
Post Options Post Options   Thanks (0) Thanks(0)   Quote hasbeenskier Quote  Post ReplyReply Direct Link To This Post Posted: June-10-2009 at 7:59pm
hasbeenskier
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuffaloBFN Quote  Post ReplyReply Direct Link To This Post Posted: June-10-2009 at 7:59pm
I saw some of your work at the river...so you have my attention!
You also used an oxymoron...Pete's gonna have a fit. LOL
1988 BFN-sold
Post Options Post Options   Thanks (0) Thanks(0)   Quote hasbeenskier Quote  Post ReplyReply Direct Link To This Post Posted: June-10-2009 at 7:51pm
BFN composite restoration.
hasbeenskier
