when engage starter all power is killed |
nc2001
Groupie Joined: August-28-2007 Location: United States Status: Offline Points: 54 |
Posted: June-21-2009 at 7:55pm |
hanks guys. just got back to the computer. i replaced the cables and she ran great all weekend. thanks again
k.o.
Senior Member Joined: January-11-2008 Location: Aruba Status: Offline Points: 363 |
we've had this happend to us plenty of times as pete suggested clean the wires or get new ones. If this happens to us on water wich is most of the times we just clean the terminals with some really light sanding and thightning the terminal back very tight. usually does the trick
Jon,
Go to the auto supply and get a battery post cleaner. Do check your cables and terminals before you go to make sure they're ok too. Water will get under the cable insulation and corrode the copper. CC never used a decent marine grade cable that's tin plated. I suggest you at least get new cable terminals. The stone on a die grinder really isn't the greatest idea! Now you may have ground grooves into the inside of the clamp preventing full contact to the battery post. Also, you probably inadventantly imbedded bits of the abrasive stone into the lead terminal - depending on the stones abrasive type, it may be a insulator!!! Make sure you check the lugs at the other ends of the cables too. They may be in bad shape as well. |
nc2001
i cleaned the posts and the inside of the clamps with a stone on the end of a die grinder. still no luck could be the cables though, the clamps and cables are original the battery is a red top optima
Jon,
Do you have one of these? Battery post cleaner: Sounds like your posts and cable ends need cleaning. What is the condition of your main cables? They could be internally corroded too. What condition is the battery in? Hopefully it's not a deep cycle. |
nc2001
when i turn the key i get power in the on position but when i turn to start it kills all power. Then i get no power even to accessories in the key on postiion. It kills everything. If i disconnect the positive battery cable and reconnect i get power again but then samething happens. The main fuse doesnt appear to be tripped. any idea whats going on. Im pulling it to the lake today for a long weekend. hope i can fgure this out.
