77 graphics resto update |
Post Reply | Page 123> |
Author | ||
DrStevens
Senior Member Joined: October-15-2011 Location: Columbus, OH Status: Offline Points: 422 |
Posted: February-18-2015 at 8:53pm |
My boat is a 1978, graphics have been repainted, if posting photos were not do difficult you all could see.
seacamper
Platinum Member Joined: June-24-2010 Location: Florida Status: Offline Points: 1056 |
Thanks Pete, I will try and look for locals that can do that. I have one in mind. I just went out and did a patch with the super duty rubbing compound by hand, because I was afraid I would smear the lettering all over the place, and I am surprised how the lettering shined up. It did smear quite a bit because of the oxidation, But I will probably go around twice with super, then down to regular rubbing compound, then start the masking. I need to do this job excluding Sat and Tues, because those are the days the boat is in use. I think I will do one side a week including the transom. I want to pull the swim platform and do the teak cleaning and oiling at the same time.
1980 Ski Nautique Boat Bar
1988 Mastercraft Tristar Open Bow 1988 Mastercraft Tristar Closed Bow 1969 Seacamper Houseboat 1986 Harris Pontoon 2004 Seadoo GTX SC + Flydive Xboard 1999 Adventurecraft |
Tom,
The alternate for the graphics lettering is to trace and take it to a vinyl sign shop. They will scan it, clean up the tracing on their computer and cut a mask. A common name for it is a Gerber mask which is a brand. It would save time from having it mask all the lettering with the fine line tape. I'm glad to hear you want to go original with paint and not vinyl! One of these days I need to do my Tique. The PO put vinyl graphics on it! |
phatsat67
Uhhh oooo Tom has the retso bug!
seacamper
So guys, it looks like Jeff used this for the wide spray:
Spray Gun And this for the border: Air Brush And this to mask the letters: Fine Line And this to mask the rest: Masking Film So he rubbed out the hull with rubbing compound right over the old lettering, accepting the fact that the letters would rub off, but still be traceable. After he was happy with the hull being cleaned up and shined up with the compound, he used the fine line to outline the outside of the lettering, and then came over all of it with the traceable masking film. He then cut the masking film using the fine line to be the actual border with the lettering, and allowing the masking film to stick to the fine line, and peeled back the traceable masking film from the lettering. He then mixed out blue Rustoleum Professional paint with toluene and did some test sprays to find the right consistency. He used the detail gun to spray the letters, then, while the paint was still tacking out, he went to black Rustoleum, and put the border on. He then pulled up the film and fine line as quick as he could. Does that sound right? Please add inputs. Tom |
seacamper
Hey Jeff,
Are you still posting? I wanted to check your brain about this thread. Tom |
Your posts are coming through just fine. Check Jeff's original post for the prep work details: http://correctcraftfan.com/forum/forum_posts.asp?TID=13844 On the paint:
sweet78
Newbie Joined: October-24-2010 Status: Offline Points: 5 |
I don,t know if my first post went through but boat looks great what color blue did you use
sweetra
sweet78
what color blue did you use the boat looks great
sweetra
Donald80SN
Grand Poobah Joined: January-12-2009 Location: Denver, NC Status: Offline Points: 3896 |
I used Woodys suggestion and used a piece of 1/2" copper pipe with a notch cut out of it to clear the screws and some silicone spray to install the rope. I had never installed rope before, maybe there is a better way, but it went in like a dream for me. [/QUOTE]
Jeff, Thanks and can you give just a little more explaination about the notch cut into the 1/2" Copper Tube. I know that some of the guys have used the Copper Tube with some soapy water with great success, but I am assuming that that 1/2" size is the ID of the Tube. I know that the guys recommend going back with 1/2" Size Rope instead of the 5/8" that came orginal. This is due to the rubber now being hard over time. How long does this tube need to be or does it matter? I am thinking three inches long. I do not unstand the notch that is cut. I understand that you will see or run into screws to hold the rub rail to the finerglass, but do you run the notch the entire length of the cooper tube so that it looks like a letter " C" but not that big of a notch? Then you align the opening on the screws and push the rope all the way around. If you could post a picture of your Cooper Tube Tool that would be very helpful. Within the next few weeks, I am going to replace my rope. I want to replace the entire Rub Rail maybe next Winter. Thanks, Donald |
77 nautique
Senior Member Joined: June-24-2006 Location: Schenectady NY Status: Offline Points: 115 |
I ment to include this in my post
( Southeast Correct Craft ) Woody 7576 South Orange Avenue Orlando FL. 32809 407-851-1965 |
77 nautique
Donald, I can't recall the part # and the box is long gone but if you call Woody @ the former Southeast Correct Craft (now a Master Craft dealer....bummer) he can get you what you need. That's where I got mine from. It was a kit. Came with 50' rail, more than enough rope and a ton of stainless screws. Oh and if you go with the rope, I used Woodys suggestion and used a piece of 1/2" copper pipe with a notch cut out of it to clear the screws and some silicone spray to install the rope. I had never installed rope before, maybe there is a better way, but it went in like a dream for me.
Air206
What type of rope do I need to get for the rub rail insert? 5/8 poly? ( 79 Transom project)
Pete, the rope rub rail may not be original on Jeff's '77, but it sure would be on Donald's '80!
Merritt, I dont believe there are any differences in the graphics from '77 to '79. Jeff's pictures in this thread are your best guide. There are no templates available unless you want to spend $550 on the vinyl reproductions. Just trace your original lettering. If youre not sure if its original, post a picture and we can tell you. |
Donald80SN
Jeff,
I love your work. Where did you get the Rub Rail? Is it a Taco Rub Rail? I do not see the Rope Rub Rail on the Taco Web-site. Maybe you just use the rope instead of the plastic insert. Even looking at it that way I am not sure about which one to use. Do you have the part number for what you have? Beautiful Boat. Thanks, Donald |
merrittarnold
Groupie Joined: June-06-2009 Location: United States Status: Offline Points: 83 |
I've looked at all the pictures and the 79 brochures, but I can't find a good picture of the shading and everything for the 79SN. Is there someone that sells the templates? Does anyone have a good, original picture of all the 79 graphics?
There are motorcycles; and there are Harley Davidsons.
There are tractors; and there are John Deeres. There are ski boats; and there are Ski Nautiques! |
Yes as long as you have the tracings needed for your sign shop to make ether the mask for paint on th vinyl. You want a decent clean surface to apply ether. |
merrittarnold
Sounds good to me. Is it best to completely remove the old graphics first? I can tell these aren't original.
Merritt,
I'd have to say that both the vinyl and paint are equal but don't worry as it won't be a yearly job. Both the paint and vinyl is affected by UV. The best vinyls are guaranteed for 7 years. That's 7 full years out in the sun so on a boat it may last 3 times that. Best protection when the boat isn't being used is a full past the waterline cover. The transom is the area that really gets the worst sun. Even a boat in a boathouse will get damage from the sun. The sunlight reflects off the water and comes up under the door. I cover my woods even when in the boathouse. Vinyl has a slight advantage when it comes to dock damage/abrasion. I'd go with the paint - It's original!!!! |
merrittarnold
Hey guys,
What's your best estimate on the life of this paint job versus the vinyl graphics? I think it looks awesome and am ready to start tomorrow, but I don't want to have to do this every year. |
Gator
Newbie Joined: July-17-2009 Status: Offline Points: 3 |
This will be the second paint job on my 1977 Nautique (I gave the first re-paint in 1987). It has the Blue lettering with black shadowing as well, and the black shadow was way easier than I thought it would be. I bought an inexpensive air brush and, with the decals obviously still on, just gently traced around the edges on all lettering and lines - sides and back - just as it came from the factory. It looked absolutely the same. Correct Craft told me they used Rustoleum as factory paint so that's what I used.
77 nautique
Pete, got the decals today when I got home from work and WOW they are perfect! Exact size. I sent the check out this afternoon during lunch.
77 nautique
Yup, got it. I will put the check in the mail first thing Monday. Thanks again for everything. Have a great 4th!!
Jeff,
I got your message on my answering machine yesterday when I got home from work. Sorry I didn't call you back but the message with you phone # was broken up and I couldn't understand it. Since I had emailed you from work earlier in the day with my address I figured you did get it. |
77 nautique
Mojo, no clear. the Rust-oleum yelds a excelent shine right off the get go. Go over everything with the 3M Finesse It using a buffer with a good quality wool pad and it looks like you laid 3 coats of clear over the entire boat. All of the pictures i posted so far there is no wax on it yet! going to do that today. As far as techinque with the air brush, all i can say is that i have never used one before this project and i was intimidated but i figured i would give it a go knowing that if it didnt turn out good i could go back over it with the blue. I thinned the black down till it almost dripped like water off the stir stick and played around with the settings on the brush and air pressure until it looked about right, crossed my fingers and just did it. Other than a good steady hand there is really nothing to it.
Andy
Senior Member Joined: July-27-2008 Location: M'boro, TN Status: Offline Points: 382 |
I'm not sure yet. I have other places I'm "supposed to be". My wife said so.
Sorry about the re-post additions snafu. I can't find the delete function. |
My Blue 82SOLD!
BuffaloBFN
Wow and what they said, luv the stands!
I have talent envy...I'd never free hand those curves; I build a jig for almost everything. |
81nautique
Grand Poobah Joined: September-03-2005 Location: Big Rock, Il Status: Offline Points: 5796 |
Jeff, Looks awesome. Don't think I'll get to see it at Lake George this year though. I think I have garage envey.
quinner
ThreadJack!!
Andy, are you coming to Green Lake, don't remember if I saw your name on the sign up??? |
