  New Posts New Posts RSS Feed - Properly Checking Engine Oil Level
boat dr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote boat dr Quote  Post ReplyReply Direct Link To This Post Topic: Properly Checking Engine Oil Level
    Posted: June-28-2009 at 2:51pm
Oil level to be checked with boat in the water. This will also allow you to look over all systems prior to firing off the motor.
Things to look for during the pre check should be ;
#1 oil level
#2 oil leaks
#3 water leaks
#4 fuel leaks
#5 tranny fluid level
#6 tranny oil leaks
All these checks will help to insure that you have a "SAFE BOATING DAY"
phospher View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote phospher Quote  Post ReplyReply Direct Link To This Post Posted: June-28-2009 at 2:44pm
i think this has came up in the past but i couldn't find it using the search function..
i'm curious how to correctly check my engine oil. the thing that throws me off is that the engine does not sit level, and when your on plane it's at even more of an angle. so should you check your the oil while the boat is sitting level or with the tongue raised a bit?
