  New Posts New Posts RSS Feed - Transmission Leak
Transmission Leak
jon4pres View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jon4pres Quote  Post ReplyReply Direct Link To This Post Topic: Transmission Leak
    Posted: July-14-2009 at 9:25pm
That is an interesting business plan.
I read the other thread about you going to aruba and got to thinking. I can offer you some a week in my dads vacation house in Kansas. :)
82 2001
jon4pres@gmail.com
Fort Scott Kansas
eric lavine View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: July-14-2009 at 12:54pm
10 years same as cash!!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote jon4pres Quote  Post ReplyReply Direct Link To This Post Posted: July-14-2009 at 12:03pm
That is good to hear. The only time I have had mine slip was when it was low the first time and I hadnt checked it. It has not slipped when it is full of oil.
I like eric's sense of humor. I like you just dont know where the money is going to come from to fix this thing.
82 2001
jon4pres@gmail.com
Fort Scott Kansas
Luchog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Luchog Quote  Post ReplyReply Direct Link To This Post Posted: July-13-2009 at 9:51pm
Jon, I've adding oil into mine for last 2 years and around 200hours of use, many of them boarding and it hasnt slipped once... just yet.
I just cant find the money to rebuild the damn thing but I'd do it without hesitating if I could. Therefore I check the oil before taking it out and before any long cruise or pulling session. It seems the drip rate on mine depends on the load the transmission handles.
I carry 2 Dexron III bottles onboard all the times by the way.
By the way, Eric is a great guy, you just have to get used to his sense of humor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jon4pres Quote  Post ReplyReply Direct Link To This Post Posted: July-13-2009 at 3:32pm
Thanks Eric
Sounds like I will get to talk to you again later.
I am sure you are a great guy but not really looking forward to it.
Jon
82 2001
jon4pres@gmail.com
Fort Scott Kansas
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: July-13-2009 at 10:11am
just to your ego, it has to come out anyways, the shaft may be pitted and probably has to be taken all the way apart anyways. summer is short and oil is cheap
Post Options Post Options   Thanks (0) Thanks(0)   Quote jon4pres Quote  Post ReplyReply Direct Link To This Post Posted: July-12-2009 at 1:46am
What??? Honestly how do you know when it is right before it blows?
Thanks for the info Eric. If possible I would like to try and just add oil though the summer and then have it fixed right this winter. If it blows will it do any additional damage?
82 2001
jon4pres@gmail.com
Fort Scott Kansas
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: July-11-2009 at 10:35am
if you want my honest opinion, im the type to keep adding oil till she blows, thats me though... 650 to 750 seeing alot of mid 80's tranny's lately....more hnestly, you need to get that tranny out right now before it blows! lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote jon4pres Quote  Post ReplyReply Direct Link To This Post Posted: July-11-2009 at 10:07am
WOW Thanks for the bad news. New questions
Should I run it until it gernades inside or if I do something now instead of when it totally quits could it save me money or keep me from doing additional damage to the engine?
What does a rebuild cost?
Eventhough it is not the news that I wanted thanks for the advice.
82 2001
jon4pres@gmail.com
Fort Scott Kansas
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-10-2009 at 1:58pm
Jon,
Seals can leak for several reasons. It's usually caused by other problems than just getting old. I'd guess it's the front seal that's the problem on yours. Pump problems will cause front seal leakage. Lots have tried just replacing the seal only to find it leak again. I too suggest sending the trans to Eric. It being a 82, the hours on the trans may be getting up to the point where it neds a compete rebuild.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Luchog Quote  Post ReplyReply Direct Link To This Post Posted: July-10-2009 at 1:15pm
it is something you can fix yourself... but it is very likely to break on itself again... unless you've already done a few.
Sure Eric will chime in soon and give you all the tips.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jon4pres Quote  Post ReplyReply Direct Link To This Post Posted: July-10-2009 at 11:51am
Where do these things usually start leaking at?
Is it something that I can fix myself? I am pretty mechanical and know a great place to get advice(thanks CCF)?
82 2001
jon4pres@gmail.com
Fort Scott Kansas
Post Options Post Options   Thanks (0) Thanks(0)   Quote Luchog Quote  Post ReplyReply Direct Link To This Post Posted: July-09-2009 at 10:54pm
there's no way you could fix it without taking it out, no serious way at least.
If it's not dripping enough on one outting that it will end empty on middle of the day, and you constantly keep an eye on it yes it could last until winter... and maybe not.
Anyway, Fantastic Finish Marine can have it repaired in no time and you will be on the water before you missed it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jon4pres Quote  Post ReplyReply Direct Link To This Post Posted: July-09-2009 at 8:30pm
I have a slow transmission leak in my 82 2001. In my attempts I can not tell if the fluid is leaking out the front or back of the transmission. It leaks enough that I add a splash of fluid everytime I put gas in it.
What do I need to do?
Slacker option: Keep checking the fluid and fix it when winter comes.
1/2 slacker option: If it is leaking out the back try to fix it in the boat.
Best option that would have my boat out of commission for a while: Take the tranny all the way out of the boat and try to fix it.
Thanks
Jon
82 2001
jon4pres@gmail.com
Fort Scott Kansas
