  New Posts New Posts RSS Feed - Boat dies once i put it into gear?
OverMyHead View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote OverMyHead Quote  Post ReplyReply Direct Link To This Post Topic: Boat dies once i put it into gear?
    Posted: July-18-2009 at 12:07am
Somebody should tell you, the flame arrestor is the canister thing on top of your carburator that sits where your air filter would commonly be on a car. There are several parts unique to marine applications that are required for safe operation. It is good to become familiar with these parts if working on your own boat, for instance you create an explosion risk if you put a standard automotive distributer on a marine engine.
1987 Ski Nautique
89Ski_Nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 89Ski_Nautique Quote  Post ReplyReply Direct Link To This Post Posted: July-17-2009 at 9:26pm
T Rag,
For starters your idle is way too high, you will need to adjust the idle and perhaps check the timing to be in the proper range. Do not adjust your idle artifically high to compensate for the engine dying while in gear. This puts a lot of load on the transmission plus makes it unsafe for slow speed manuvering around the dock and or other boaters.
As Eric pointed out while out of the water, please check your engine/tranmission alignment (read that as mis alignment)perhaps it is way off causing excesive drag. Also perhaps check your transmission / propshaft connection to ensure the propshaft rotates freely with any excessive binding.
C-Bass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote C-Bass Quote  Post ReplyReply Direct Link To This Post Posted: July-17-2009 at 6:15pm
Originally posted by Luchog Luchog wrote:
Originally posted by tieguy88 tieguy88 wrote:
Yes the choke is working. WHere is the flame arrestor?
If you cant find the flame arrestor I really doubt you can tell the choke is in working order.
Haha, yeah that's kinda what I was thinking. It's like saying "Yeah it has plenty of oil. Where is the dipstick?"
Craig
67 SN
73 SN
99 Sport
85SN
Luchog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Luchog Quote  Post ReplyReply Direct Link To This Post Posted: July-17-2009 at 12:04pm
eric lavine View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: July-17-2009 at 6:31am
thats right up there with where is the outdrive, also look into a safety boaters coarse, it too will help you identify important parts and the workings of a safe boat
BuffaloBFN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuffaloBFN Quote  Post ReplyReply Direct Link To This Post Posted: July-16-2009 at 2:47pm
I think Eric may have called it. Your idle is too high and that will also put a hurtin' on the tranny.
1988 BFN-sold
tieguy88 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tieguy88 Quote  Post ReplyReply Direct Link To This Post Posted: July-16-2009 at 2:20pm
rpm run about 1100 then when i put it into gear it just dies. but when its warm it run in gear at about 800 rpm and when in neutral is around 1000
T Rag
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: July-15-2009 at 1:22pm
What rpms do you see?
Post Options Post Options   Thanks (0) Thanks(0)   Quote tieguy88 Quote  Post ReplyReply Direct Link To This Post Posted: July-15-2009 at 12:41pm
T Rag
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: July-15-2009 at 10:06am
you could have some serious mis-alignment also
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-14-2009 at 11:12pm
Is your choke working? Pull the flame arrestor and see if it's closed when cold and then it should open gradually as the engine warms up. BTW, Fords are notorious for being cold blooded!!! What RPM did you crank the idle up to?
Post Options Post Options   Thanks (0) Thanks(0)   Quote tieguy88 Quote  Post ReplyReply Direct Link To This Post Posted: July-14-2009 at 10:29pm
I have a 1985 Ski Nautique 2001. The boat fires up great and once going it will stay in gear and won't die. However when it is cold or I have just been floating in the water, as soon as I just nudge it in gear, it is hard for it to stay at the correct rpm without dying. I have turned the idle up but this doesn't seem to help because once I have been going the idle is WAY to high. what is my problem?
T Rag
