  New Posts New Posts RSS Feed - Repairing stripped screw holes.
maXjr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote maXjr Quote  Post ReplyReply Direct Link To This Post Topic: Repairing stripped screw holes.
    Posted: July-23-2009 at 4:21pm
overtons has a gel coat kit http://www.overtons.com/modperl/product/search.cgi
i ran my 89 nautique aground and ripped the rear end out (strut,and pused rudder up into bottom of the boat (lake jorden nc). i took it to where i bought it and had it fixed. white lake marina did a super job fixing and matching the gel coat. i dont own the boat now, but its still running on the lake.
http://www.whitelake.com/service.asp
Terp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Terp Quote  Post ReplyReply Direct Link To This Post Posted: July-16-2009 at 12:11pm
Thanks Pete, I appreciate your advice.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: July-15-2009 at 12:29pm
John,
I'm not a big fan of the Marine Tex. I put it in the same catagory as Billys Mays's Miracle Putty!! Not good for doing most jobs because of it consistency. It's too thick to really get into the underlying surface to prime for good adhesion.
For the gel repair, get one of the gel repair kits at the marine supplies or on line. Go2marine is a good source. Mix the coloring pigments into the base in very small amounts. I use the tip of a tooth pick until the color is correct then add the hardener. On vertical surfaces you may need to put a piece of tape over the gel to keep it in place until it sets up. I also tape around the repair area so when you hard block wet sand the new gel down to level it, you don't sand the surounding area. Get it down to the level of the tape, remove the tape and finish sand/buff. I like 3M fine line tape. It's thin and water proof/solvent proof.
Stripped screw holes can be filled with a epoxy. Even the small double syringe type you find at the hardware is fine. Fill it up, drill a new pilot hole and run the screw back in. If you can get to the backside, using a machine screw, washer and nut is even better.
Terp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Terp Quote  Post ReplyReply Direct Link To This Post Posted: July-15-2009 at 11:31am
Hey guys, any recommendations on the best method for repairing stripped tap holes in gel/glass?   I picked up some Marine-tex for the job but wanted to ask for advice before I apply it. Any pros/cons?
I've also picked up a few dings in the gel coat. What's the best product for this repair? I asked the fellow at West Marine but he seemed unsure so I wasn't convinced. I tried clicking on one of Pete's links to a product from a previous post but it wouldn't link.
