Inboard Motor Cover Barefoot |
rookie
Groupie Joined: July-26-2009 Location: florence,ms Status: Offline Points: 74 |
Posted: August-11-2009 at 1:14am |
i have an 83 b.f. w/ 454 i'm parting out yours for 100.00 vinyl is still very good as is the trim and handle/ see my add in parts for sale/ "parting out b.f. nautique"
dave |
do it right the first time...
robertbruder
Senior Member Joined: July-16-2009 Location: Indiana Status: Offline Points: 335 |
Hollywod,
That would be awesome if you would be willing to let me know the dimensions. I may have found a cover off a southwind that measures 48" L by 33" W. Not sure on the necessary height. Thanks For your help! Rob |
Hollywood
There are a couple guys on here that can probably measure for you. I have access to a 88 BFN with the 454 in it. It is short and wide. A Martinique or Riviera from the same era would probably be the same, either way look for a deep V hull with a big block. A big block Ski Nautique motorbox would probably work but it will be taller.
I've been meaning to compare our 88 SN SBF box to Johnny's 88 BFN BBC box for some time now, can probably do it Saturday. |
robertbruder
I am looking for a fiberglass motor box cover for a 1987 Barefoot Nautique.
Does anyone know the dimensions for this particular model? Is this motor cover a custom size due to the big block? Or will any motor box cover from another Nautique fit? If someone has a Barefoot and would be willing to measure the dimensions of their motorbox for me that would be awesome! Thanks in advance, Rob robertbruder@inbox.com |
