  New Posts New Posts RSS Feed - Changing Water Pump Impellor
damonwells View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote damonwells Quote  Post ReplyReply Direct Link To This Post Topic: Changing Water Pump Impellor
    Posted: August-03-2009 at 2:23pm
GREAT ... thanks everyone. cheers,
OverMyHead View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote OverMyHead Quote  Post ReplyReply Direct Link To This Post Posted: August-01-2009 at 3:40am
Very easy job, even I can do it. Digital before photos of orientation work also. But you have to look close.
1987 Ski Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote behindpropeller Quote  Post ReplyReply Direct Link To This Post Posted: August-01-2009 at 2:30am
Be careful when you put the pump back on. Note the orientation....in fact mark "top" on the top side of it.
Tim
rmm025 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rmm025 Quote  Post ReplyReply Direct Link To This Post Posted: August-01-2009 at 1:38am
Definately don't overtighten while you are on the water. I sheared a bolt on time due to its age and corosion and ended up having to be towed in.
bill1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bill1 Quote  Post ReplyReply Direct Link To This Post Posted: July-29-2009 at 6:03pm
don't over-tighten the 3 bolts when putting back together-----been there - done that.
bill
Post Options Post Options   Thanks (0) Thanks(0)   Quote damonwells Quote  Post ReplyReply Direct Link To This Post Posted: July-28-2009 at 5:15pm
Thanks Craig. 1990 Ski Nautique, FORD 351, PMC
C-Bass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote C-Bass Quote  Post ReplyReply Direct Link To This Post Posted: July-28-2009 at 3:06pm
John,
What is your boat/engine? This is a pretty simple chore. Don't use any petroleum products, just use dish soap on the impeller, that will be more than enough to lubricate it, plus when you see huge suds coming out the back you know it's pumping it thru . You shouldn't have to use any sealant, just the supplied gaskets/orings.
Some will say to make sure you mark the orientation of your pump before you remove it to prevent putting it on backwards. Good luck.
Craig
67 SN
73 SN
99 Sport
85SN
Post Options Post Options   Thanks (0) Thanks(0)   Quote damonwells Quote  Post ReplyReply Direct Link To This Post Posted: July-28-2009 at 2:01pm
Can someone walk me through changing the water pump impeller please, thanks. Haven't done this on the Nautique before. What should I use to grease the vanes and inside the housing > petroleum jelly, marine grease ? Should I use a sealant on the brass gasket > what kind ? Any other suggestions ?
thanks, cheers, John
