Prop anti sieze? |
nates78ski
Platinum Member Joined: January-24-2005 Location: United States Status: Offline Points: 1041 |
Posted: April-19-2005 at 8:45am |
IO's & outboards have grease on the shafts because they have splined shafts. The idea of lapping the new prop to the shaft is a good one. Also if it is stuck remove the prop with a prop puller.
GottaSki
Guest |
To me, it sounds like a recipe for a sheared keyway and/or distorting of the slot if it were to slip every fwd/rev.
Lap the prop to the shaft so the tapers exactly match, and removal problems go away. |
Tim D
The prop and shaft will not corrode together. The shaft is stainless steele and the prop is nibral (nickle,brass,aluminum). The tapered shaft and the tapered inside of the prop are "wedged" together causing it to stick.
Tim D
SS 201
Senior Member Joined: October-20-2003 Location: United States Status: Offline Points: 232 |
NO
Rick
Senior Member Joined: March-03-2004 Location: United States Status: Offline Points: 338 |
I always use a little waterproof grease on the shaft before I install the prop. It makes it so I don't have to crank really hard on the puller. I have left the prop on for 3 years and still had it slide off with a little tap of a plastic mallet.
David F
I have never heard of any doing such a thing. I believe it is not required. Grease or anti-sieze is usually used to prevent corrosion in high temp or high moisture applications. Since props are nibrile (sp) or SS and the shafts are SS, neither will corrode and fuse together.
pmt2234
Guest |
When reinstaling my prop, should I coat the taper with some kind of grease or anti sieze compound? If so, what kind?
