TWC vs TSC |
quinner
Posted: August-19-2009 at 2:50pm |
The Sport / Air / Pro Air are essentially the same boat, how they are appointed generally would have influence on their designation.
There were (2) different hulls available, the TSC and TWC, TWC being the wake hull and TSC being the ski hull. In theory the only boat you could get the TWC hull with was the Pro Air. The Air and Sport always had a TSC hull. Towers/ballast/etc. were available on any of the three models. |
Terp
Senior Member Joined: November-12-2008 Location: Deep Creek Lake Status: Offline Points: 339 |
Can anyone comment on the differences between the wake for these 2 hulls? For example...If I take a '99 Pro Air and run it unballasted, will there be a significant difference in the wake vs a Sport w/ the TSC hull? Also, I noted the brochure for '99 lists the Pro Air w/ a TWC hull. Could it be had w/ a TSC hull as well? The reason I ask is, in searching for previous posts on the same topic I came across a post by Quinner Pro Air props which mentioned a TSC on a '99 Air.
