  New Posts New Posts RSS Feed - Propeller for MC hull with PCM red. gear.
Luchog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Luchog Quote  Post ReplyReply Direct Link To This Post Topic: Propeller for MC hull with PCM red. gear.
    Posted: September-07-2009 at 10:17pm
Kapla yes there are 3 blade versions for the 1 1/8 shaft, the thing is the MC hull allows for a larger diameter propeller and Panchito sacks the hell out of this boat.
kapla View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: September-07-2009 at 3:44pm
Tell panchito he needs a nautique!!! lol...
to bad about the 1 1/8, my recomendation would be on the 1442, unfortunately there is nothing similar to it for that size of shaft...
<a href="">1992 ski nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote Luchog Quote  Post ReplyReply Direct Link To This Post Posted: September-07-2009 at 1:48pm
Well, for you that dont know, I'm selling ACME propellers down here in Argentina.
The issue here is most boats are not standarized, so every prop is a helluva questions to the owner and testings before ordering.
So this friend of mine has an Argentinian version of the MC PS195 hull (1997), he has a PCM GT40 Pro Boss paired to a PCM 40A 1.23:1.
He's currently running a repaired OJ 13.75x15.5 4 blade.
He loads the hell out of this boat and needs some more power. Shaft diameter is 1 1/8''
I suggested him ordering the ACME 1464 wich is 13.5x14.25 .105c
There is also the 1236 wich is the same size but .150c
What's the reduction gear propeller gurus (tim benjamin) opinion on the topic?
