Ballast problem |
75 Tique
Grand Poobah Joined: August-12-2004 Location: Seven Lakes, NC Status: Offline Points: 6130 |
Posted: October-13-2009 at 1:05am |
Instead of 2 big sacs, go with 8 small ones. It gives you more flexbility in placement around the boat. Thats the route Paul went and look how nicely his boat is riding.
Donald80SN
Grand Poobah Joined: January-12-2009 Location: Denver, NC Status: Offline Points: 3896 |
OMG Too True |
OverMyHead
Grand Poobah Joined: March-14-2008 Location: MN Status: Offline Points: 4861 |
First of all those compliment your correct craft nicely. You will not likely ever stop those from bouncing around, especially in a moving boat. Just place them how they work best for you and then keep a close eye on them, it will likely be a very "hands-on" process. Make sure you take good care of them, if they are well adjusted and well maintained you will get amazing rides for many years, although you will have to stay on a short rope. Dont forget to rub in a little UV protection now and then. Remember replacing those can get expensive. If you dont want the responsibility I am sure someone on this site would be proud to have them in their boat and care for them properly. Keep'em original. Ahhh fun with metaphors.
1987 Ski Nautique |
Fatboy206
Groupie Joined: August-26-2008 Location: Dubai Status: Offline Points: 57 |
I reckon if you push them together and blow them up, always works for me!
Kristof
Grand Poobah Joined: October-08-2007 Location: Bree, Belgium Status: Offline Points: 3399 |
OMG... Whole face and stomach still hurting from LMAO!!
Q: Why don't women fart...? A: Because they can't keep their mouths shut long enough to build up the required pressure... |
hotboat
Gold Member Joined: March-28-2009 Location: Conn Lake Pa Status: Offline Points: 814 |
Its the airleak from the mouth that presents the most problem
Brian
skicat
Platinum Member Joined: May-18-2006 Location: Duluth, GA Status: Offline Points: 1129 |
I don't see the problem. So what if the boat leans a little. I believe I would put up with it!
hotboat
Thank you for all your help, I was just going to add a set to the right rear?
Brian
eric lavine
only 5000 more mammory shots till summer
uk1979
Platinum Member Joined: June-13-2007 Location: United Kingdom Status: Offline Points: 1424 |
Release spinnaker's to allow sacs to fall and center.
Lets have a go
56 Starflite 77 SN 78 SN 80 BFN |
harddock
Platinum Member Joined: June-04-2008 Location: Toontown, MA Status: Offline Points: 1763 |
You need to locate the valves and just tweek 'em a little they will center themselves.
MartyMabe
Grand Poobah Joined: February-21-2006 Location: High Point,NC Status: Offline Points: 3991 |
You ain't right!!! You can tell it's the off-season again. The Boys are bored allready! LOL!!!!
eric lavine
if you put the fly high pole between them it might even the sacs out a bit
hotboat
How would you go about fixing a leaning problem when the fat sacs get off center? |
Brian
