  New Posts New Posts RSS Feed - 89 wiring Diagram
89 wiring Diagram
SNobsessed View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SNobsessed Quote  Post ReplyReply Direct Link To This Post Topic: 89 wiring Diagram
    Posted: October-17-2009 at 10:47pm
Chris - If you add a power outlet, you may want to consider running an additional ground up to the dash. The original wiring was slightly undersized from the factory & adding more load will only make it worse. Watch you guages when you turn on the blower & running lights, they will go down!
inglesideshawn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote inglesideshawn Quote  Post ReplyReply Direct Link To This Post Posted: October-17-2009 at 5:08pm
my 89 has a ground strip under the dash.. also the wires off the button was just zip tied up to the harness, i think mine was an orange wire..if that helps at all...
1989 nautique
Chris4x4gill2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris4x4gill2 Quote  Post ReplyReply Direct Link To This Post Posted: October-08-2009 at 4:50pm
Also, I want to add a power outlet (cig lighter style) I am planning one of the Acc switches for power, whats the best place to go for a ground?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris4x4gill2 Quote  Post ReplyReply Direct Link To This Post Posted: October-08-2009 at 4:45pm
I need to use the 89 dash wiring diagram from the reference section but when I click on it it says the file is "locked". Anyone have a copy of the file they could share? I need to know what wires go to the horn switch and the alarm on the dash.
