  New Posts New Posts RSS Feed - Ski Pylon
Ski Pylon
Fl Inboards View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fl Inboards Quote  Post ReplyReply Direct Link To This Post Topic: Ski Pylon
    Posted: December-24-2009 at 12:11pm
Dan: Tim Offered you a straight out swap for a standard Pylon. Get in contact with him and if it is not what you want then get back to me.
Jody
dan1166 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dan1166 Quote  Post ReplyReply Direct Link To This Post Posted: December-23-2009 at 8:16pm
Yes, I would be interested in the one from the 2000 sport. Since I am the one that started this post, I guess I should respond once in awhile. I have a 1999 Ski Nautique with the extended pylon. I never use the extension and would like a standard height pylon. What are you asking for the pylon and what kind of shape is it in. Let me know, and thanks again
Dan
Dan, The STS Man
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fl Inboards Quote  Post ReplyReply Direct Link To This Post Posted: December-23-2009 at 6:13pm
Some where during the late nintey's I even shortend the pylon a couple of inches for the Ski Nautique. More than likely the year that the machined area below the spool was added to address the newer trick releases. Man! seems like ages ago!
FYI If some one is looking for a pylon I have the one out of My 92 as it now has a straight current pylon. And I have one out of a 2000 sport!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: December-23-2009 at 4:48pm
Again, that clarifies what Gary was saying that if the hand finish wasn't done well the pylon got rejected after the annodizing. The gray pylons are what I'm talking about 1993-1998.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fl Inboards Quote  Post ReplyReply Direct Link To This Post Posted: December-23-2009 at 3:37pm
Was not sure when we went to the first teflon pylons. If one looks at some early coated pylons some were more Gray then black. Around about the time we went to the straight Pylons we also got better with the coating process. I remember seeing many a pylon getting rejected because of color or other cosmetic problems. After the CNC machine started being utilized many of these problems went away. If memeory serves me we were running a Mazak CNC turning center.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: December-23-2009 at 3:22pm
The CNC makes sense, when you run your fingernail down an "old" pylon it doesn't make a noise. The newer ones have tiny ridges and make a "ZZZZZZZZZZZZ" sound.
The 1993 brochure says the pylons are teflon coated.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: December-23-2009 at 3:10pm
Much like chrome Kevin, anodizing reflects the base. If the aluminum is polished before anodizing,it will be glossier. And since Jody says they changed to cnc machining this is what must have made a difference.Anodizing is basically a controlled corrosion with a dye added to make the color, no dye and it's called clear anodizing. I also understand that it's hard to keep colors consistant from job to job.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fl Inboards Quote  Post ReplyReply Direct Link To This Post Posted: December-23-2009 at 2:12pm
It had to do with the anodizing the earlier Pylons were anodized in a standard type process when we went to the sraight pylons we incorperated a teflon type anodization. Also around that time we went from hand turning on a lathe to A CNC machine, this made for a more refined finish before they went off to the coating company.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: December-23-2009 at 1:27pm
What can you tell us about the finishes between the two? The earlier bent black pylons are somewhat "dull" in while the true straight pylons are a much deeper and glossier black.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fl Inboards Quote  Post ReplyReply Direct Link To This Post Posted: December-22-2009 at 11:58pm
Originally posted by Hollywood Hollywood wrote:
I'm fairly certain that the true straight pylon started in 1999. Knowing Correct Craft though, there could be a mix of 1998s with bent and straight standard pylons. The tall ones were all definitely straight, and available in 1998.
I have a 98 SNOB here in the shop, it has straight pylon.
ros12705 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ros12705 Quote  Post ReplyReply Direct Link To This Post Posted: December-22-2009 at 11:50pm
have one 5 footer in Fla,,, 150.00 with strapps.... 321-779-9831 Mie Ross or e-mail me...
Post Options Post Options   Thanks (0) Thanks(0)   Quote behindpropeller Quote  Post ReplyReply Direct Link To This Post Posted: October-29-2009 at 3:09pm
Dan-
I just re-read your post. I will trade you your 5' pylon for the short pylon.
tim.cochrane@gmail.com
Tim
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: October-29-2009 at 1:42pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote behindpropeller Quote  Post ReplyReply Direct Link To This Post Posted: October-29-2009 at 12:52pm
I will have one available next week. $150.00
Tim
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hollywood Quote  Post ReplyReply Direct Link To This Post Posted: October-29-2009 at 12:43pm
I have one from a 95 available. It is black but has a very slight bend.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dan1166 Quote  Post ReplyReply Direct Link To This Post Posted: October-28-2009 at 11:47pm
WTB: Standard height pylon(around 53 in) for a 1999 Ski Nautique. My boat has an extended pylon, which we do not use. The pylon should be straight(no bends) and a black finish.   Thanks
Dan, The STS Man
