  New Posts New Posts RSS Feed - '75 OMC Coolent Hose Layout
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Topic: '75 OMC Coolent Hose Layout
    Posted: November-03-2009 at 10:17pm
Nate,
Here's the thread that Luciano mentioned. OMC cooling hose problem with center riser style manifolds
Post Options Post Options   Thanks (0) Thanks(0)   Quote 75 Tique Quote  Post ReplyReply Direct Link To This Post Posted: November-03-2009 at 10:15pm
Edit: See Pete's post below. We linked it/posted it at the same time.
natebracing View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote natebracing Quote  Post ReplyReply Direct Link To This Post Posted: November-03-2009 at 9:38pm
Hey guys, thanks for the quick replies. I'll take a pic of the motor tonight and post them.
-Nate
1975 Ski Nautique - White & Red
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: November-03-2009 at 8:24pm
Nate,
I just went into the diaries and set the search between 1973 and 1977 and there are lots of boats to look at! The engine type is listed on the main page so you don't need to open them all. Look for a OMC listing and then see if they have included any engine pictures. You may get a idea on the plumbing.
Pictures of your engine would be great. Also, does it have OEM or aftermarket manifolds on it? What specifically doesn't make sense? How does it run - any hot spots?
Welcome to CCfan.
Luchog View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Luchog Quote  Post ReplyReply Direct Link To This Post Posted: November-03-2009 at 8:08pm
is your's the one with the hoses coming out of the exhaust manifold risers?
Could you post a pic of your engine?
Another member posted a thread about an OMC 350 for that same reason a few months back.
Post Options Post Options   Thanks (0) Thanks(0)   Quote natebracing Quote  Post ReplyReply Direct Link To This Post Posted: November-03-2009 at 8:02pm
I purchased a 1975 Ski Nautique with the OMC 350 (GM) motor in it, but the way that the coolent hoses are run, doesn't make a whole lot of sense to me. I was hoping that someone could send me a picture of the correct coolent hose layout.
-Nate
