engine removal advice please |
Darrel
Senior Member Joined: June-16-2004 Location: United States Status: Offline Points: 340 |
Posted: October-19-2004 at 3:09pm |
engine alignment isnt that hard but it does take some patience. I just did it again on my 95 SN. There is an article on"inboardtalk.com" that explains everything in great detail. Look in the engine/trans section. Its mostly a lot of time and small movements of the engine and checked with a feeler gauge. Good luck.
Darren Sangster
Guest |
I have pulled the engine & tranny out of my 76 and it was very easy. It's back in now, but I haven't put in the shaft yet to see how close it is lined up. Is it just common sense? Or are there acutally procedures? E-mails would be really appreciated!!! dsangstr@mts.net
Thanks |
Darrel
Tryan, Is this the same article? "Get in Line" by Jack Hardin? The article is on inboardtalk.com under their engine/transmission heading. I used it this weekend and it is quite a process. I admit to getting confused in the last couple steps.
Lew Beck
Guest |
If you still have the alignment info I would like a copy. Thanks in advance.
E-mail: skilew77@yahoo.com |
Barracuda
Moderator Group Joined: November-17-2003 Location: United States Status: Offline Points: 998 |
Howard, my advise- Just pull the entire engine and tranny.It's really not hard to align the engine to coupler after reinstalation.People make it out to be a big deal- it's more carpentry than mechanics.go for it- you'll be surprised how easy it is.btw, why you pullin the motor?
jmesser
Groupie Joined: March-20-2004 Location: United States Status: Offline Points: 84 |
Tryan,
If you still have the alignment info I would love a copy. Thanks in advance. Johnnie Messer (johnniemesser@bellsouth.net) |
Johnnie Messer
tryan
Senior Member Joined: November-12-2003 Location: United States Status: Offline Points: 345 |
i can email anyone an funky alignment procedure that i recieved from mark at marine gears. the procedure compensates for slightly bent shafts and flanges similar to rotaing a tire on a rim to offset the imbalance. i'll try to post it on inboardtalk and link it, but i have it if anyone wants to read it.
Rick
Senior Member Joined: March-03-2004 Location: United States Status: Offline Points: 338 |
Its a good idea to mark the mounting bolts before you move them After you replace the motor/tranny you have to realign it to the prop shaft. Specs call for alignment to .002" to .003" Thats really close.
66polyhead
Senior Member Joined: December-20-2003 Location: United States Status: Offline Points: 171 |
Dan is correct, Howard. The engine and tranny pulled as a unit is much easier. On my "66" the engine and tranny are supported as a unit, At a perticular angle. On four points. All four mounts sit on jack bolts, with jamb nuts underneath, maintaining the heigth and angle, and lock nuts, secureing the top. I was fortunate enough to have a forklift, and a steel top table to seperate my tranny from the motor on. be sure to tape the jamb nuts, or reference mark them in some way. Have fun, be safe, and good luck
danman
Groupie Joined: February-04-2004 Location: United States Status: Offline Points: 56 |
howracer- Just pull the motor and trans out
as one assembly - It is very easy. I stripped off nothing of my motor when I pulled it. I just disconnected my fuel line,exhaust hoses, water pickup hose,main wiring harness has a connector thats wrapped in electrical tape, and my power and ground. four bolts - 2 for the tranny mounts and 2 for the motor mounts I had the whole thing out of the boat from start to finish in about 15 minutes. When you do get it out - find an old tire - lower the oil pan straight into the middle of the tire -then you can seperate the trans from the motor hope I helped! |
howracer
Newbie Joined: February-21-2004 Location: United States Status: Offline Points: 3 |
thanks. i will check realignment..
howard |
tryan
it's called a dampner plate. visualize a clutch disc bolted straight to the flywheel sans the friction material.
no such thing as a self alignment thing in my world. i would advise you to check it after re-installation. |
howracer
thanks.... apparently there is a splined shaft from the trans that slips into something connected to the engine. i plan to remove the cast engine mounts at the engine so the engine should realign itself upon installation as the mounts won't be removed from the hull.
howard |
tryan
i have never done it that way, but it will work. when it pulls free from the transmission you better be absolutly positively sure that the oil pan will not bust a hole in the hull.
you'll want to mark the motor mounts, so you'll be close to your original alignment when you re-install it. i would think the pole and that section of the floor would have to go. |
howracer
1991 ski nautique... 351 ford PCM. i have everything stripped off the motor and wish to pull it while leaving the transmission in the boat. i have pulled lots of motors from cars but don't know how the trans and the motor are connected/disconnected in my boat. is it possible to move the motor straight forward while leaving the transmission in the boat? do i need to remove the skier tow bar? i really would like to leave the trans in the boat if at all possible.
thanks in advance, howard coleman |
