  New Posts New Posts RSS Feed - 86 2001 Prop Comparisson
Ride_Klein View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ride_Klein Quote  Post ReplyReply Direct Link To This Post Topic: 86 2001 Prop Comparisson
    Posted: May-23-2005 at 5:25pm
Keith and All-
Thanks for the kudos, but I've learned far more from this site then I've given back. Great site for trading information on our boats.
Texas88- We kept the same top speed buy are pulling 150 RPM more to do so.
Keith- I'll get that information to you next week. I'm out of town again, and never put the data onto the computer.
Keith View Drop Down
Admin Group
Admin Group
Owner / Operator of CorrectCraftFan.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote Keith Quote  Post ReplyReply Direct Link To This Post Posted: May-20-2005 at 1:40pm
Ride_Klien,
Great job! Email me your results and we'll format them into an actual Webpage in the site - similar to my review of the 540. Feel free to also send any photos.
Thanks,
Keith
Former:
97 Sport Nautique
1994 Ski Nautique
86 Silver Nautique
79 Mustang
Texas88 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Texas88 Quote  Post ReplyReply Direct Link To This Post Posted: May-20-2005 at 2:43am
Wow, what a great job you've done there Klein. So with the 542 you gained 150 rpms and speed stayed 43 mph? The guys at Acme said they could add a little cup to the blades if the engine got too high of rpms and that may add a little speed too.
Thanks,
Bryan A. Texas 88 Ski
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ride_Klein Quote  Post ReplyReply Direct Link To This Post Posted: May-17-2005 at 8:13pm
Sorry for the delay, but as life does, it got busy. I wasn't able to get an Acme 540 for the test, but I tested the other three. I've got all the data written down from our trip at home and I'll get it all put together tonight. All I can comment on now is the "feel" of the prop.
One thing that I'll add is our top speed is actually 43 mph at 4400 RPM and not 45 when verrified by the Gps. Also, if you haven't had your prop rebuilt in a while go do it now even if you don't think it needs it. I hadn't registered any hits or dings on my older one, and it was not even on the same playing field with the 542 and the rebuilt. (I'll take this to mean that I have registered a number of small dings to the prop without noticing them, either way the prop looked fine to a visual inspection, but was not once we compared it to the other two)
The Acme 542 is a huge improvement over both the other props. Keep in mind I was comparing a 2 year old 13x13, a freshly rebuilt and balanced 13x13, and the acme 542. It was much smoother, much stronger, and much quieter.
The difference in hole shot and power is attributable to the 11.5 vs. 13 pitch. I'd heard it felt like adding 40 hp and I'll vouch for that. There was a discernable differencerence just "seat of the pants" when you give the boat power. The added power was great, and it was noticeable throughout the powerband. The Acme really shined when we put the weight in, and started pulling the rider. With the Acme 542 it was an easy pull to get the rider up and going, about 1/4 throttle was all it required. With the rebuilt and ballanced 13x13 it took about the normal 1/2-2/3 throttle. The same for the unrebuilt 13x13.
I was expecting the power, but the thing that blew me away was the smoothness and the noise reduction. Right out of the hole the 542 was much better. Jump on it and the boat goes. With the Acme 542 there was no vibration throughout the powerband and speedband. It was as ultra smooth as I've ever felt the boat. Idle, cruise or WOT, the 542 felt smooth. The rebuilt 13x13 was very smooth up to about 25 mph. Once we got above that you began to feel what I would call normal prop vibrations. WOT was ok, but with a slight noticeable vibration. Had I not been comparing it to the 542 I wouldn't have noticed them. The 2 yr old unrebuilt 13x13 was a different story. (Keep in mind no hit or dings that I know of to this prop just normal use, and the only time I'm not driving this boat is when I'm behind it sking or riding). I hadn't noticed it before, but this prop was not very smooth compared to the other two. A small shutter was present when you applied a heavy amout of throttle, and at WOT, you could feel a noticeable prop vibration.
The noise from prop vibration was all but gone with the Acme 542. All we could hear was the 351
As we added weight to the boat the vibrations increased with both of the 13x13's. I still couldn't feel one with the ACME 542.
Our Top speed stayed the same unweighted, but we do pull 150 more RPM (4550 compared to 4400)
The rudder feel was about the same between the rebuilt and the Acme 542. Only difference was in the turns the boat felt a bit more solid, I can't tell if this was an actual difference or my body wanting to feel like the $300 prop I just bought was better.
The wake at slalom speeds was a little smaller, but the rooster tail was a bit longer. I had heard one reviewer comment on this before. The wake also seemed a bit softer when crossing it. Overall I'd say I like the wake equally between the props.
Driving a slalom skier was much better. Speed control was extremely easy. The same can be said for a wakeboard rider on an aggressive cut. Only mild adjustments were required to the throttle with the Acme compared to significant adjustments with the rebuilt.
I did notice a more pronouced prop walk when reversing the boat. The first time I came to the dock was a surprise. After that I got used to it.
My overall impressions of this prop are WOW. Great buy especially if you're going to be using the boat for wakeboarding at all. If you only use for the boat is slaloming or barefooting I would get the 540. (Keep in mind that I did not have the chance to test this prop, but I can imagine the vibration elimination and feel would be comparable).
I should have the numbers all organized and up either tomorrow or the next day. If you've got questions ask away.
80nauts View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 80nauts Quote  Post ReplyReply Direct Link To This Post Posted: May-14-2005 at 3:50am
I am curious too
Post Options Post Options   Thanks (0) Thanks(0)   Quote Texas88 Quote  Post ReplyReply Direct Link To This Post Posted: May-12-2005 at 1:24am
Hey, Not to rush you or anything but I sure am curious about those numbers from the different props. Please post them when you can. Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ride_Klein Quote  Post ReplyReply Direct Link To This Post Posted: May-07-2005 at 2:45am
Bryan-
We can turn 4500 rpm in our boat and push 45 mph. We are running the original 13x13 federal prop that was rebuilt a few years ago. I verified the speed with gps last season, but haven't checked it this year.
The 542 is a 13x11.5 and the 540 is a 13x12. Unfortunately I haven't picked up the prop yet, so I can't tell you what we get on the top end. The shop got the prop in this afternoon so I should have a report on Monday. I've never pulled a footer so I can only comment on the top end with no load just cruising.
Thanks for the input on the surfer. We've tried a couple things, but I think we just need a little more weight in the boat to get the sweet spot a bit longer.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Texas88 Quote  Post ReplyReply Direct Link To This Post Posted: May-06-2005 at 1:35am
Ride_Klein
I am on Lake Travis and the Pedernales River in Austin. i can only get 42 mph from my 88 2001 with 4400 rpm. I would sure like 45 mph and be able to hold it with a footer. I am less concerned with the wake than the speed. 2001's don't have a good barefoot wake anyway.
I wonder what the pitch diff is between 540 and 542 and if there is a diameter difference.
Surf set up for our family is a 500lb fat sac on each side of the motor cover touching the rear seat. Make sure your surfe board is big enough such as the liquid force surfer. Then find the sweet spot be weighting the front foot to go faster than the wave and weighting the back foot to move back on the wave. A real balance act, most people stay too far back on the board.
PS how do you get 45 mph out of your 2001, how many rpms are you turning at that speed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ride_Klein Quote  Post ReplyReply Direct Link To This Post Posted: May-05-2005 at 12:38pm
Texas 88
Unfortunately the prop hasn't gotten in yet so I don't have the test information. I'm hoping it will be in today and I'll be able to get it done this weekend.
I chose the 542 for a couple reasons. First, when I talked to the guys at Acme they said I shouldn't loose any top end from the original to the 542. I would gain a little bit with the 540, but our boat will do 45 allready, and I don't need to go any faster. Second, they said that the 542 would be superior at holding speed through an aggresive cut by the rider wakeboard speeds and equal at slalom speeds. Finally the hole shot would be better with the 542.
The articles and reviews I've read online from people that switched to the 542 seemed to reflect these opinions and so I went with it. There's a guy in Dallas that has a 540 on the shelf and he offered to bring it out for our tests. If he and I can get together I'll throw it in there and have a great comparisson.
There are a couple downsides I can see to the 542. First, I might start using more gas, but all the guys online that I talked to after they switched to the 542 said they hadn't noticed a difference. Second, there might be the possibility of running over the RPM limit for the boat. I don't think this will be an issue for me since we very seldom run at WOT. Third, one guy mentioned the rooster tail getting bigger and longer at slalom speeds. Nobody else could verify this. I'll see if I can tell a difference, but I'm not short lining anything so it shouldn't be an issue.
I've never barefooted before, but if you'll tell me what speed you guys run I'll grab a picture of the wake at that speed with no weight in the boat.
We usually keep the boat at Lake Athens. I live in Dallas and have the boat back here for a couple weeks completing a few projects and doing some maintenance. What lake are you on?
Final question for you, what is your surfing set up for your boat? I tried to surf behind our boat last year and couldn't ever get the hang of it. I was fine with the rope, but couldn't find the sweet spot. Seemed like the wave was tall, but the rideable area very small. Any advice on weight, board, or just general newbie surfing suggestions.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Texas88 Quote  Post ReplyReply Direct Link To This Post Posted: May-05-2005 at 12:47am
Hey thanks for the test info. I have an 88 2001 and am comsidering changing props to the 540. Why did they say to go with the 542 and what is the difference? We do 60% wakeboard and surf and 40% barefoot so I would like to know your top speed and rpms on those props and maybe how the speed holds up at top speed. What lake are you on?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ride_Klein Quote  Post ReplyReply Direct Link To This Post Posted: May-03-2005 at 1:58pm
I've got a 1986 2001. Until this past year I used it to Slalom almost exclusively, but I've gotten the wakeboard bug and with that bug have started to add some weight. The stock prop is not cutting it anymore, and with the new prop technology I've made the jump to Acme.
I did a ton of research online and talked with the guys at Acme. We use the boat for 50/50 slalom and wakeboarding as well as the joy of cruising the lake in the best boat ever made. The guys at Acme recommended the 542 over the 540 so we wouldn't ever have a problem with weight.
I'm going to do a head to head comparisson between the 3 props I have access to.
Original 13x13 (Rebuilt 2 years ago, no nicks just normal use)
Rebuilt 13x13
Acme 542 13x11.5
The prop should be in tomorrow, and if we can get a break from the wind down here in Texas I'll hit the lake and get some results. I should be able to get a good comparisson between all three props.
I've gotten some recomendations from other sites and right now I'll be documenting the following things for each prop. Speed verified by GPS. Incidentally we run about 1000lbs of weight 400 in the back (behind the seat), 250 on each side of the motor box (bags touching the rear seat), and 100 up front. It will be myself and a spotter for the trip.
Top Speed
0 - 20 times (weighted and unweighted)
0 - 36 times
RPM's for 20 mph (weighted and unweighted)
RPM's for 36 mph
Time from 20 - off plain
Time from 36 - off plain
Feel raiting for vibration
Feel raiting for steering
Feel raiting for ability to hold speed while rider/skier is cutting
Wake Pictures at 20 (Weighted and unweighted)
Wake Pictures at 36
There's been some talk about the rooster tail increasing at slalom speeds, as well as the wake "softening" and I'll try to comment on that.
Anything else you guys/gals want to know?
