  New Posts New Posts RSS Feed - Horn Switch
Horn Switch
Greg_SA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Greg_SA Quote  Post ReplyReply Direct Link To This Post Topic: Horn Switch
    Posted: February-03-2011 at 10:45am
Hi Ben,
Sounds good! ;-)
Where in South Africa are you? I'm in Cape Town - feel free to drop me an email (from my profile page)!
I'm tryuing to get my buoyancey certificate!
Cheers
Greg
1989 Ski Nautique (SN2001)
ben View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ben Quote  Post ReplyReply Direct Link To This Post Posted: January-26-2011 at 8:23am
Now fitting these:
Complete glove box unit
Accessory Socket
Trailer Guide Pole Pads
Cup Holder Flush insert
Horn Switch
Motor Box Hinge
CONTROL SINGLE MV - used through 95 CC boats (black plastic knob)
Vent
Lower section of pod
ben View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ben Quote  Post ReplyReply Direct Link To This Post Posted: January-26-2011 at 8:10am
Greg,
I ordered a new horn swith and misc parts from the States to Johannesburg. Busy restoring an '89 as well. Must say service is excellent and well worth fitting original parts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Greg_SA Quote  Post ReplyReply Direct Link To This Post Posted: January-26-2010 at 6:35pm
Excellent, thanks very much. That will make sourcing a replacement switch much easier.
Regards,
Greg
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: January-26-2010 at 10:00am
Greg,
3 to 5 amps for the small electrics. Depends on the manufacturer. Most momentary switchs can handle that. If some one has put a larger horn on the boat such as a dual horn trumpet, they can go up to 20 amps and then a relay is needed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Greg_SA Quote  Post ReplyReply Direct Link To This Post Posted: January-26-2010 at 9:30am
Hi,
Does anyone know how much current the typical horn on a 1989 (or similar) Ski Nautique draws?
I need to replace the switch, and I don't want to order the original as I am in South Africa.
Thanks,
Greg
