Stringer Removal- Was it hard? |
WakeSlayer
Posted: January-29-2010 at 7:50pm |
My secondaries just came out, except for the very back on a couple.
I ground a line about half to a full inch all the way down on the primaries. I removed all the glass. Took a flat bar and pounded into the last little lip between the wood and glass, all the way, both sides. After that just a few good shots with the BFH and a little prying, they came out. Once you break the bond on the sides there is not much holding them in there. The bottom is not well adhered to the hull. |
Mike N
1968 Mustang |
jbenbri
Groupie Joined: November-11-2004 Location: United States Status: Offline Points: 54 |
Just removed one secondary but it was difficult. I have heard of them "popping right out" but that was not the case. Where did I go wrong? Cut the glass about 1/2 to 1/4 inch above hull and then started pulling. I did notice the hull flex some and may have caused some stress cracks. I don't want to mess the other ones up. Thanks.
