Motor mounts & rotted stringers |
Post Reply | Page 12> |
Jim_In_Houston
Posted: May-16-2005 at 6:42pm |
Sounds good to me.
mackwrench
Senior Member Joined: February-25-2005 Location: Gone Status: Offline Points: 190 |
Jim, My 2 cents are that rot is rot is rot, if you put a patch over it, thats a short term fix. You need to cut all the rot and replace as necessary before the entire length of stringer is rotted. I would follow Davids advice. ........
I was very fortunte that my rot was just confined to the lag bolt aera's, for a 40 year old boat! |
NO LONGER A MEMBER
Jim_In_Houston
Good info David. I still think you should write a book. Even a small pamplet - ask for donations on a website.... anyway, keep the good info coming. (I will have to re-glass the stringers on my '66 before I can put it in the water.) I have had some tell me to just lay a new stringer along side the old stringer, glue 'em and screw 'em and then glass the whole thing to the hull. Opinions?
David F
Tleed:
Well, not great news. You have a couple options: 1. Attempt to pour in epoxy and hope it is not endless. If you discover it to be endless (thinned epoxy runs in continuously) then go ahead a pour in thickened epoxy (thicken with talc powder or fine saw dust) and set your dowel. Reinstall motor mount bolts (after curing) and monitor over time. 2. Cut off top inside corner of fiberglass over stringer until you find solid wood, if any. If you find solid wood, then yes, you can splic in new wood. Either construct a rabbit joint or shallow taper joint and glue with epoxy. First coat each side of joint with resin, then glue with thickened resin to fill voids and prevent the resin from running out of the joint (second step before first step cures out). Replace fiberglass covering. Let me know if you need pointer here. IMHO: The fiberglass covering over the stringe is more important than the wood as far as the structure is concerned, so this needs to be repaired properly. There are many boats with totally rotten wood stringers that have not suffered structural failure due the fiberglass handling most if not all the loads. The wood is mainly there to hold screws and act as a form. It also absorbs shock and vibration to some extint. |
Jim_In_Houston
I noticed the hose and I wondered where you got them. Nice.
mackwrench
Jim, The front engine brackets are as before, I drilled out the center "lag" bolt hole to accept the new mount. The new mount is about the same height as the old wood "shim" and now has threaded adjustment up & down. The rear was a little more..... I did fab the rears, their is a 3/4 or so shaft the comes of the trans mount, I cut the OEM mount off that shaft and welded a "L" peice of stainless to it, drilled a 3/4" hole in the top for the mount. It seems hard but was really simple do do. A good way to lose some of the "vibes" these old tubs have! Maybe my pics are not so detailed, I'll take some more and send them to you.... No comments on my stainless braided hose exhaust? My dad worked for a major chemical trucking company and it was used to pump some kind of acid...
NO LONGER A MEMBER
tleed
Senior Member Joined: August-24-2004 Location: United States Status: Offline Points: 267 |
Drilled out the holes where my motor mount lag bolts were. The consistency of the shavings could best be described as "rich, dark mud". I figured it would be bad, but there really wasn't much that was hard there.
So how bad is "bad"? I'm not afraid to fix it, but now I'm wondering how far I need to dig into the stringer. Do I need to cut out a whole section and splice new board in? If so, how do you go about doing that to preserve structural integrity? Thomas |
tleed
What size are the lag bolts supposed to be? Mine are so rusty I can hardly tell.
My local Lowe's has 1/2" stainless 6" long, but they look way too big in diameter. Thomas |
Jim_In_Houston
Yes I am. Probably for my '66. I am looking very hard at your pics. It looks like you have fabricated brackets that bolt to your motor and trans frames. Is that right?
The rear mounts on my '68 sit on a small piece of plywood (for a shim). It looks factory but it looks real cheezy. I'm just in the thinking stage right now. |
mackwrench
Whew! Glad you guys got that stright! lol! Jim, you gona look into those mounts?
NO LONGER A MEMBER
David F
Jim:
You have it correct. The other benefit to epoxy is that it does not shrink as it cures whereas polyester resin does. Epoxies have three drawbacks: 1. Can cause skin allergies after cumulative prolonged exposure...so keep it off your skin. 2. Significantly higher cost than polyester resins. 3. Harder to work with when wetting out fiberglass mat or roving. Also, does NOT disolve the binders in regular mat, so "sewn" mat should be used. |
Jim_In_Houston
My understanding is the epoxy resins are generally stronger (whatever that means) than the polyesters. I also read that polyesters do not bind well to epoxy resined structures. The trade off is that cure time can be "adjusted" with polyesters by changing the ratio of hardener to resin and not so with epoxy. I am sure there are more differences but I am way outside the realm of things I know anything about.
mackwrench
I thought "epoxy" was an adhesive like glue. I drilled a row of 5/8 holes in top of stinger and filled with just regular fiberglass/polyester resin. The stainless "plates" pictured above then bolted through where filled. But I had very little rot, mostly where the old lag bolts were.
NO LONGER A MEMBER
David F
Morfoot's got it right. I would add about 20% acetone.
Tleed: You got the wrong stuff. The epoxy that my local Home Depot's carries is Bondo brand and comes in two one pint cans held together with a white plastic cover. The cans are generally light blue in color and are located next to the fiberglass cloth and polyester resins. It is a 1:1 ratio resin with a medium to high pot life (30-45 minutes). |
Morfoot
Grand Poobah Joined: February-06-2004 Location: South Lanier Status: Offline Points: 5325 |
Jim,You want to add your acetone after the resin is mixed up. You don't want a 50/50 mix as it will thin it out too much. Add a little at a time to make it water like. It will delay set up a little but not a whole lot. Use a heat gunor hair dryer to heat up your resin to make it soak into the cloth better if you don't cut it. WARNING- don't get to hot for too long or it WILL kick it off.
Jim_In_Houston
The last two times I was in Home Depot they did not have any marine epoxy. They used to have it in 1 gallon cans. Maybe they no longer carry it.
tleed
Just got back from Home Depot. Not sure I got the right stuff. It's Loctite brand "Aquamarine Epoxy". It has .85 fl. oz. in a syringe-type container that has 2 parts. Container says it dries gray. Also says it sets in 10 minutes & it's for "Surfaces exposed to intermittent water immersion".
The store clerk took me right to it when I asked for "marine epoxy". I asked if they had something else like it. He gave me a vacant stare like how could I ever want anything else. Thomas |
Jim_In_Houston
David, when do you add the acetone? Do you wait until the epoxy begins to setup in the mixing cup? About how much acetone do you add? 50%?
1 to 1 mixed epoxy to acetone? More? Less? Does adding acetone delay the setup? |
David F
Well, sort of. Dr. Rot is essentially expensive thinned epoxy resin. Go to Home Depot, buy the two part marine epoxy resin that is sold in the paint section. Buy a pint of acetone and you are set. Another expensive product mentioned often is "Git Rot" is all essentially the same. Make it yourself and save. And you will have the resin to glass over the dowels when you are done (not thinned, of course).
tleed
Wow! Thanks for all the help! Not into Eskimo rolls. Guess I'll have to make the proper repairs.
David: when you say "epoxy resin", do you mean the Dr. Rot stuff? I've been checking out this website and someone said there's a product for wood repair at Home Depot that's just as good. Someone else complained about another similar product also available on the web that they said was junk. Any recommendations? Thomas |
mackwrench
Yep
NO LONGER A MEMBER
Jim_In_Houston
Are all 4 mounts the same part?
mackwrench
Maybe this will link to them:
http://ebasicpower.american-data.net/Merchant2/merchant.mv?Screen=CTGY&Store_Code=eBasicPower&Category_Code=MER6G |
NO LONGER A MEMBER
mackwrench
I got those from www.ebasicpower.com
Part # MMDF210 $22 buck each |
NO LONGER A MEMBER
Jim_In_Houston
Man I like those mounts. Where do I go to get them?
Jim_In_Houston
These pics are from Todd (mackwrench):
mackwrench
Jim Pics are in the mail..... I taken a 4"X6" flat piece of stainless, bent it into a L with 4" bolted to inside of stringer, the top of the "L", 2", sits on the top of stringer under engine mounts, mounts are bolted to stainless. The mounts have a lot of vertical adjustment, and the best is they are rubber insulated, OEM parts from big block mercruiser, so the vibrations are almost nil. My orginal setup however had lag bolts and the "various size" wood spacers and shims to align engine. Now every thing is bolted to stringers & mounts, (all stainless hardware) been running this deal for 4 years with no issues whatso ever.
NO LONGER A MEMBER
kenny g
Senior Member Joined: December-13-2003 Location: United States Status: Offline Points: 318 |
my 68 barracuda 318 also uses the 2" wood spacers under the front mounts.and to align the motor to the shaft it needs 1/2" under the rear ones.
kenny g
Jim_In_Houston
Rosser, it will either be pushed forward into your back or it will start doing Eskimo rolls under your engine box. Either way is real bad - especially if your family is in the boat.
Todd, send the pics to jim@drivesys.com and I will post them. I would like to see them myself. |
Rosser
Newbie Joined: April-11-2005 Location: United States Status: Offline Points: 19 |
See what you guys think.I far as I can tell,all of the force applied from prop to push boat forward is applied to engine hold down bolts.If these fail, engine will be pushed forward until prop hits bottom of boat. Yes?
1971 Skier holman&moody 1971 Mustang holman&moody
