  New Posts New Posts RSS Feed - 91 Excel steering problem
hotboat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hotboat Quote  Post ReplyReply Direct Link To This Post Topic: 91 Excel steering problem
    Posted: January-31-2010 at 1:56pm
Mine is a bit of a bear to steer as well,they drive/handle in a whole different world than the direct drive.
Brian
eric lavine View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: January-31-2010 at 1:06pm
I always joke around with people that i was the guy that worked on the steering on the boat that went up into the stands a few years back at Sea-world over here, luckily no one got killed
WakeSlayer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WakeSlayer Quote  Post ReplyReply Direct Link To This Post Posted: January-31-2010 at 1:03pm
I agree that you need to go through the system as Pete is suggesting. Do note that those boats have only one skeg, and are quite tail heavy. My 92 BFN was a bear to turn. I always thought about adding a fin or two to it.
Mike N
1968 Mustang
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: January-31-2010 at 10:10am
Rick,
You'll need to isolate where the binding is. Disconnect the cable from the tiller arm and then manually turn the rudder. If it feels pretty easy, turn the wheel and see if you still get the binding. I'd say it's very possible you'll need a new steering cable.
sandbar53 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sandbar53 Quote  Post ReplyReply Direct Link To This Post Posted: January-30-2010 at 11:56pm
recently purchased 91 Excel. We only used it twice before the end of the season. When I make a 180 turn, the steering is EXTREMELY hard (needing two hands) under power. Then I have to forcefully bring it back straight. The first 1/4 of a turn each way seems normal. It doesnt feel like a bind, it feels like a load, maybe on the rudder. While stopped the steering feels normal. Any ideas ????
Previous owner said "the boat is made just to go straight" (Bologna!)
Thanks for any help.
Rick
