bfn header options/price |
Posted: February-02-2010 at 7:08pm |
Jody, do those Glenwoods have snails or elbows, or are they just the manifolds? If they have risers, what size outlets do they have?
Im not sure what youre looking for pricewise (I may be interested) but aluminum logs/risers can be had for relatively cheap ($150-200). |
Fl Inboards
Grand Poobah Joined: January-20-2008 Location: United States Status: Offline Points: 2119 |
I have a set of Glenwood logs for a BBC that I might be intersted in parting with if the price is right!
Headders under a motor box??? Better be fully jacketed! |
Like I mentioned in the other thread, I believe Bassets are dry headers. Some may be water injected for cooling- which means small amounts of water are sprayed into the dry exhaust. Either way, theyre not jacketed so they wont work for us.
Lots of companies out there making fully jacketed headers for BBC's though... Hi-Tek, CMI, Eddie Marine, Imco, Lightning, Stainless Marine, etc. Expect to pay between $1500 and $6k. The ones that look like manifolds instead of headers are cheaper. The ones that have individual jackets around the runners are more (CMI, etc). Pay attentention to material as well- many are SS, but some are aluminum. Some are a mix (Lightning uses SS inner and steel outter). The better performing, nicer looking, and more SS in the construction, the more you'll pay! With the diagonal bolt pattern on the flange, you may be correct that you cant swap sides. You may need to stick to a v-drive pattern, while the direct drives can use the more conventional I/O or jet pattern. Also be aware of clearances- some of the offshore or jet boats have a lot more room under the hatch (or no hatch at all) so they can go super tall, flare out wide, or extend back pretty far. You may be less concerned about the length and width, but DD guys need to keep all 3 in mind if they want to fit them under stock boxes. |
hotboat
Gold Member Joined: March-28-2009 Location: Conn Lake Pa Status: Offline Points: 814 |
Maybe these?
Basset-price I saw 1100,have to assume that is a piece or everyone would have them Someone help, if I remeber correctly the flange on a bbc is not reversible, correct? |
Brian
