  New Posts New Posts RSS Feed - Need some help 79SN
Need some help 79SN
79nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Topic: Need some help 79SN
    Posted: February-10-2010 at 11:52am
they are both the same in that area if you look at it closely. But it is for the motor and tranny mounts to sit a little lower on top of the 2x10
79TiqueRebuild View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79TiqueRebuild Quote  Post ReplyReply Direct Link To This Post Posted: February-10-2010 at 11:11am
Thanks Pete
I found a link somewhere on this site that took me to here photos. The pictures I am referring to are under floor construction but you can also see in the carpet group. Have to go to work now. Monty
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: February-10-2010 at 8:47am
Monty,
Where did you find those pictures? On site? If so, get a link posted to the thread. Wondering if he mentions the reason he dropped the main stringers forming the channel. I don't know why they are there. They look to far forward for the engine/trans mounts and they are typically full height there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79TiqueRebuild Quote  Post ReplyReply Direct Link To This Post Posted: February-09-2010 at 10:30pm
I still am not getting it. The areas I am talking about are circled in red. I just don't see how it went from 1st picture to the second. Is there another 2x next to the main stringer that the plywood comes up to?
Is that channel made for water drainage to the bilge or better engine access?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: February-09-2010 at 9:43pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79TiqueRebuild Quote  Post ReplyReply Direct Link To This Post Posted: February-09-2010 at 9:07pm
I need some help on the channel next to the engine where the floor meets the stringer. I've posted the pictures that I have been using as a guide on my rebuild. Don't know whose boat this is.
It looks like there is a channel next to the stringer and the floor and the plywood comes over to it.
Does anybody have any pictures that show what this should look like?
                                      Thanks, Monty
