70-71 Scoops Wanted |
cudas51
Newbie Joined: March-31-2007 Location: United States Status: Offline Points: 20 |
Posted: March-04-2010 at 11:14am |
Clark; I don't have the scoops you need to trade but, would be interested in buying yours, if they are the older style I need. Can you send a pic? john
storm34
By narrow, taller scoops do you mean the rounded scoops? And wider, flatter do you mean more square? Narrower, Taller? Wider, Flatter? |
Cslaten33
Senior Member Joined: December-21-2009 Location: Tulsa, OK Status: Offline Points: 150 |
I have a 74SN. It has the narrow taller scoops. They are not vinyl. They are fiberglass and gel-coated. I am still looking for the wider flatter scoop. If anyone can find me a set. I will gladly send you my front and two rear scoops from the 74SN
Thanks Clark Slaten
Look again! I dont believe they changed to the wider/flatter vinyl covered scoops until '75. Before that, they were either gel'd or painted. FrankT has made a mold to reproduce the early round scoops- you may want to touch base with him. |
cudas51
Hi Pete; I'am just continuing to collect parts for the project. If I could just get a sample of each I could make some new scoops. I don't have a pic. I looked at the Diaries and found that 70-71 Nautiques and Martiniques used scoops that were plain colored gelcoat. 72 and up they changed to a flatter style and they were either gelcoat or covered in vinyl to match the interior.
JD,
Are you finally moving forward???!!! GL 10? |
connorssons
Platinum Member Joined: January-17-2009 Location: Michigan Status: Offline Points: 1414 |
What slyle ,do you have a pic
storm34
storm34
Wasn't someone looking to sell theirs and buy or trade for the older versions?
cudas51
I am looking for (1) large and (4) small fiberglass gelcoat deck scoops that were used on 70-71 CC's. Not the vinyl covered versions used later. I don't care about the condition or color. jd
