  New Posts New Posts RSS Feed - Color Matching for 91 Teal Gel-Coat
tryan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tryan Quote  Post ReplyReply Direct Link To This Post Topic: Color Matching for 91 Teal Gel-Coat
    Posted: February-29-2004 at 6:38pm
if you have any sun fade from 13 years, you might buff a hidden area to see if the color hue has changed. peel off a sticker will also show the fade.
but you might have to go a shade down if you even the slightest fade. get a small stock sample and test it first. there is a color chart on the link i posted.
woodyelc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote woodyelc Quote  Post ReplyReply Direct Link To This Post Posted: February-25-2004 at 2:51pm
call spectrum color 800-754-5516 they will be able to help. there part numbers are 2313 for cool gray and 2314 for teal. hope this helps
woodyelc
Post Options Post Options   Thanks (0) Thanks(0)   Quote tryan Quote  Post ReplyReply Direct Link To This Post Posted: February-25-2004 at 11:58am
donald at minicraft. get your wallet out
jcor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jcor Quote  Post ReplyReply Direct Link To This Post Posted: February-25-2004 at 11:51am
Does anyone have a color code or a good way to match the Teal and Grey Gel-Coat that was on the 1991 Nauti? I would really like to find a preblended pigment to match but that is probably asking too much. Does Correct Craft offer any blending ratios for off the shelf pigments?
