  New Posts New Posts RSS Feed - glove box lift
glove box lift
David F View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David F Quote  Post ReplyReply Direct Link To This Post Topic: glove box lift
    Posted: July-19-2006 at 10:52am
I think "gas spring" is a more widely used description/terminology. "Gas Shock" is more desriptive of an automotive suspension component.
I think this is the post referenced above.
bkhallpass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bkhallpass Quote  Post ReplyReply Direct Link To This Post Posted: July-19-2006 at 7:52am
Johnnyc,
It should be called a "gas shock." BKH
Livin' the Dream
M3Fan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote M3Fan Quote  Post ReplyReply Direct Link To This Post Posted: July-19-2006 at 7:16am
Napa has the exact replacement in several strengths. The stocker is a 20lb lift, but I got a 40lb lift which really works nicely. Should be about 23 bucks. Rick over on planet nautique has the exact part number from Napa listed in an old post over there.
SkiMe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SkiMe Quote  Post ReplyReply Direct Link To This Post Posted: July-19-2006 at 1:23am
They have them in the boat us catalog. I just replaced mine and it was an exact replacement.
Johnnyc View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Johnnyc Quote  Post ReplyReply Direct Link To This Post Posted: May-19-2005 at 8:54pm
where can I get the lift ( not sure what you call 'em, the piston thing that holds up the rear glass in a suburban) that holds the dash glove box open. I tried auto parts, all they have are the long ones
