  New Posts New Posts RSS Feed - GT40 trans ?
GT40 trans ?
eric lavine View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Topic: GT40 trans ?
    Posted: April-26-2010 at 10:07am
Lewy, is that from your John Holmes super sucker kit?
lewy2001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lewy2001 Quote  Post ReplyReply Direct Link To This Post Posted: April-25-2010 at 10:42pm
this is what I used to change my tranny fluid.
89 Ski
Post Options Post Options   Thanks (0) Thanks(0)   Quote fanofccfan Quote  Post ReplyReply Direct Link To This Post Posted: April-25-2010 at 1:51pm
1/4" black DOT airline fits in the hole nicely. automotive stores usually have it. i then had to retrofit it to my pump with the forever useful "black tape".
lonestar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lonestar Quote  Post ReplyReply Direct Link To This Post Posted: April-25-2010 at 1:27pm
Ya, Im going to pump it out I guess. I have a sweet little hand pump, however to get to the traans fluid you need a hose that is almost as small in diameter as the dipstick. There is no way a turkey baster or the like could work unless I rig up some really small diameter hose to it I guess.
lonestar
kapla View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: April-22-2010 at 10:56am
pump it out through the dipstick...use a suction gun, a turkey baster or like system to remove the oil....
no drain holes....
Its pia but once you get familiar on the optimal tool to use, you do it in 5 minutes...
<a href="">1992 ski nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: April-22-2010 at 10:07am
pump it out, or pull a line and fire the boat, at op temp
Post Options Post Options   Thanks (0) Thanks(0)   Quote lonestar Quote  Post ReplyReply Direct Link To This Post Posted: April-22-2010 at 10:06am
Thanks, the manual is informative but as far as I can see dose not let you know where the drain is.
lonestar
SN206 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SN206 Quote  Post ReplyReply Direct Link To This Post Posted: April-22-2010 at 12:31am
Post Options Post Options   Thanks (0) Thanks(0)   Quote lonestar Quote  Post ReplyReply Direct Link To This Post Posted: April-22-2010 at 12:25am
I have a 98 SN GT 40, the plate on the trans says pcm 40. Where the heck do I drain the fluid on this thing ? My 88 I just use a little hand pump and its done in 2 min. Any ideas. thanks
lonestar
