Marine teak |
Author | ||
SN206
Grand Poobah Joined: February-25-2009 Location: Fort Worth, TX Status: Offline Points: 2339 |
Posted: May-07-2010 at 5:11pm |
ryanr091@aol.com
quinner
Steve,
If factory almost certainly would have been an option, mine were. Either way, good to see Ski racks after the WL shot of your boat with a tube in it, LOL. Ryan, About 45k but they threw in the boat, LOL. Really don't know as they did not break the pricing down when I ordered the boat. If you are interested the MFR tag on the mats have contact info, Aqua Mats or something like that, they refer to the mats as "carpet runners", there are (3) pieces total, send me an email and I could forward their phone number. |
SN206
Hey Chris, how much did those carpets cost ya? |
Swatkinz
Platinum Member Joined: December-03-2003 Location: Lexington, SC Status: Offline Points: 1307 |
Quinner, I'm 99% sure they are factory. Not sure what years they offered them or if they were standard equipment or optional.
Steve
2011 Sport/Air 200 Excalibur 343 2017 Boatmate Tandem Axle Trailer Former CC owner (77, 80, 95, 88, all SNs) Former Malibu owner (07, 09) |
quinner
Curious if those ski racks where factory installed, pretty cool either way. The Modern "Factory" version in my boat are polished aluminum, not as perty but do the job.
form&function
Senior Member Joined: August-21-2009 Location: OK Status: Offline Points: 342 |
I checked and the only pieces I have are the fillers for the back seat.
sorry I got your hopes up. |
Swatkinz
F&F,
Also don't know if it matters (probably not), the ski rack pieces that i need are the ones closest to the stern of the boat. They are probably identical to the more forward rack pieces, but just in case not. |
Steve
Swatkinz
F&F,
Wow, you obviously have the very best/easiest solution for me. Just to recap and since you have replacement parts instead of just scrap teak, I actually need 3 total pieces. I need the two pieces in the last picture posted (the actual ski forks piece as well as the smaller base piece that screws to the floor) and also the teak strip that runs along the gunnel on the starboard side in the first posted picture (The lower most one, the one closest to the floor). Man, I don't know what they are worth. They are unavailable thru correct craft, but pretty easily reproducable once you get the teak. I'm assuming yours would at most need a light sand and oiling. Give me a price, I'm sure we can reach a deal. Steve |
Steve
form&function
Oh crap,I just realized the piece you need is in my scrap parts pile.Tell me what you think its worth.
SN206
Don't think the peice I have will work for you, sorry.
form&function
African teak is a nickname for a similar but different species that half assed companies substitute because its a ton cheaper.It has a different grain,color and weather cracks within a few years.Real species of teak take close to thirty years to mature and of course has been depleted,substituted for farm raised seven year old baby trees.I have no idea how good this new teak is but the peices in general are small.
Steve,
I understand your analogy regarding the rebar. Yes the break is where you would expect it - right with the grain. Personally, I'd just try the glue first. If you do want to dowel it from the backside, I'd use one of the grooved dowels made for glue retention rather than just straight dowel stock. The premade dowel pins are usually hard maple or equal. |
Swatkinz
Roger, the bigger piece at it's widest is about 7 inches. Thanks for your help though.
With regards to the gluing suggestion, I thought about gluing it, but I only think that would work on the larger of those two pieces and I only think it would work on the larger piece if in addition to the poly glue that Pete suggested if a dowel could be glued in through the back of that rack through the broken piece to serve as a sort of rebar structure. Sorry for my explanation here. I'm fairly handy with wood projects, but can't find the vocabulary to explain myself at the moment. If I went the glue dowel route, I'm guessing the dowel wouldn't necessarily have to be teak, any suitable suggestions for that? |
Steve
Polyurethane glue. It will work on oily woods. Elmers "Ultimate" or "Gorilla" Do not use one of the "white" glues even if it's Titebond III that's claimed to be waterproof.
Clamp it up, wipe the excess with a solvent rag and then come back and check on it. The poly expands as it cures and will seep out until it sets up. |
YooperSully
Senior Member Joined: August-07-2009 Location: Hancock,MI Status: Offline Points: 316 |
How wide is that at it's widest? If it's five and a half then I could send you some ipe.
87' 2001
YooperSully
I'd glue and clamp them. Look for a wood glue in a green bottle, it's meant to be used in wet environments, the name however escapes me right now.
87' 2001
SN206
The piece I have may work. It's up at the lake. May sneak up ther this week for a quick run. When I do I'll take some measurements.
Swatkinz
Ryan,
Here's a slightly better picture of what I need to fix the ski rack. The longer strip of teak on the gunnel I can worry about later as it's functional for now. Regarding the ski rack, here's a better photo of the two pieces that make up that problem and some measurements. The larger piece is approximately: 7/8 thick, 15 long and 7 wide The smaller piece is approximately: 1/2 thick, 3 7/8 long and 2 7/8 wide Thanks for your willingness to help. Steve |
Steve
The last time I was over at my hardwood lumber yard which was at least a year ago, the Teak was at $85 a board foot!!!
Wiki Teak for the 3 real teak species. |
SN206
Teak as gotten stupid expensive! I saved a peice that might work for you after I had the back two peices redone on my '98 Take some measurements. I might have a peice large enough to work.
Swatkinz
So Pete is Teak just Teak? In my search do I need to be looking for something more specific? |
Steve
TX Foilhead
I've got a mirror as you walk into my house that is made of African Teak, it looks the same to me. The story was that they used them for railroad ties in South Africa a long time ago, they last a very long time, but the wood is now valuable enough that they are taking them out and selling the scrap ties to lumber mills.
I've never heard of ether "marine" teak and never heard of it coming out of Africa. I'd have to say this is a different species that looks like teak! |
Swatkinz
Ryan,
Not real good with the photo upload and especially the paint thing, but the red line shows a strip along the gunnel that I need to replace. Also, there rear leg of a ski rack that has split and needs to be replaced. I was looking for enough to cut/shape/refab both of those pieces. Thanks, Steve |
Steve
SN206
How much do you need?
Swatkinz
Is all marine teak the same? I'm trying to buy some scrap off of ebay that a seller is listing as African Marine teak. Is that the same kind of teak that would've been used in the trim pieces on my 88?
Steve
