How to remove gas tank |
Jim_In_Houston
Posted: May-26-2005 at 6:27pm |
Here ya go jimbo. All of the fuel connections are via hose held by hose clamps. The clamper boards that hold the tank in place are showing their age - I'll probably make new and coat with resin. Two of the clamping studs turned when I tried to unclamp the boards - had to lock two nuts together on the ends of the studs to hold with a wrench while I loosened the nut. The clamping nuts were 7/16" socket size. I had to use a swivel and a 1/4" drive to reach the rear starboard side nut. Thanks for the good info David.
David F
Jim:
Now your talking. Like Bill said, make SURE you ground the filler neck to the fuel tank as you do not want static electricity to blow you up. Usually a copper wire is folded over the ends (and into the hose) of the rubber hose before the hose is installed on the tank and filler. Therefore the wire makes contact with both pieces. The Hose clamps are installed over this wire to help hold it in place. |
Jim_In_Houston
I just discovered that there is a hose that runs from the filler neck to the tank with a hard-to-get-to hose clamp on the tank. I should have the tank out in a jiffy.
Bill336
Senior Member Joined: October-12-2004 Location: United States Status: Offline Points: 106 |
I pulled my tank and wasn't able to remove the deck fill fitting. Mine is a 78 and I had to cut the fuel fill hose as it was very solidly stuck to the fill and the tank and it was only 4 or 5 inches long, so there was no flexibility. I'm still a couple weeks away from putting it back in, but I'll get a new section of fill hose and ground the deck fill to the tank.
jimbo
Jim-- Let me know how it turns out. I've got to pull my tank to replace the sending unit.
James |
David F
You mean there is not a rubber hose connecting the two, but rather just the filler neck inserted directly into the tank? Try to visualize how CC would have installed the tank to begin with. I vote tug.
Jim_In_Houston
OK. I removed the screws that fasten the filler neck to the deck. The filler neck wobbles and feels like it is pressed into a rubber gasket. I don't know if I am to just force upwards (while twisitng back and forth) or if there is some kind of clamp somewhere that is holding this thing to the tank.
Jim_In_Houston
I am going to remove the gas tank from my '68 to install a tach pitot tube and to go ahead and install an electric fuel gauge sender unit. I do not know how to remove the filler neck and I do not know what I will run into with the rear vent. Anyone?
