  New Posts New Posts RSS Feed - No Water strainer??  what the heck...
eshowcase View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote eshowcase Quote  Post ReplyReply Direct Link To This Post Topic: No Water strainer?? what the heck...
    Posted: May-06-2010 at 9:20pm
Originally posted by tullfooter tullfooter wrote:
Welcome Ian.
I don't have a strainer on my boat, it is on my list of things to do to the boat. Make sure you check the cleanliness of the intake side of the tranny cooler. It will "strain" some materials that you want to clean out.
Did you, by chance, pick up the SNOB in Michigan? I was watching a '92 SNOB for sale in Oxford.
Steve
No, but close... I picked mine up in Wisconsin.
tullfooter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tullfooter Quote  Post ReplyReply Direct Link To This Post Posted: May-03-2010 at 12:13pm
Welcome Ian.
Steve
Play hard, life's not a trial run.
'85 BFN
'90 BFN
White Lake, Michigan
Post Options Post Options   Thanks (0) Thanks(0)   Quote eshowcase Quote  Post ReplyReply Direct Link To This Post Posted: May-03-2010 at 12:37am
Thanks everyone.
Post Options Post Options   Thanks (0) Thanks(0)   Quote behindpropeller Quote  Post ReplyReply Direct Link To This Post Posted: May-02-2010 at 9:00pm
www.mcmaster.com has strainers.....less expensive than skidim and made in the USA :)
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-02-2010 at 8:56pm
Ian,
If you run the boat is bad water then yes. If nice water then no.
eric lavine View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: May-02-2010 at 8:50pm
first stop after the strainer, the cooler, little bitty holes that couldnt pass a kidney stone
Kristof View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kristof Quote  Post ReplyReply Direct Link To This Post Posted: May-02-2010 at 6:42pm
Had the same discussion with a few people on this site. But, I'm with Dave on this one. Didn't have one on mine either, but I'm in for the comfort too, as stated by Dave, so I ordered one from Skidim. Love to see the clutter swirl around in that clear bowl.
The "slender grey cilinder" is indeed the tranny cooler...
- Money doesn't make one happy, but when it rains cats and dogs, it's still better to cry in a Porsche than on a bicycle...
OverMyHead View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote OverMyHead Quote  Post ReplyReply Direct Link To This Post Posted: May-02-2010 at 6:03pm
People argue for and against using the metal strainers on this site, but I personally am comforted seeing the clear bowl fill each time I start the boat after its been out of the water. I believe the slender grey cylinder is the tranny cooler. Someone wiser than I will give you a definitive answer.
1987 Ski Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote eshowcase Quote  Post ReplyReply Direct Link To This Post Posted: May-02-2010 at 5:44pm
Hi folks,
I just picked up a 1992 snob, has the standard ford 351w pro-tech. Doing the standard spring tune-up work to get the boat ready... I went to clean the water strainer, this is the clear/white plastic screw on container, o-ring seal, with a metal screen strainer... good to clean out regularly. Anyway... to my surprise, there isn't one!
The water intake hose goes from the pick-up in the bottom of the boat, around the tranny and through a slender grey cylinder, then under the motor straight up front to the water pump/impeller.
Is this an issue? Should I have a strainer? Was this common in some boats?
