  New Posts New Posts RSS Feed - stern light lens
stern light lens
heath View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote heath Quote  Post ReplyReply Direct Link To This Post Topic: stern light lens
    Posted: May-06-2010 at 1:52pm
You guys are right.. looks like someone switched mine out.. Look at this picture of a 68 that looks mostly original..
The hunt for a jetson style stern light begins!
heath
'cuda
Post Options Post Options   Thanks (0) Thanks(0)   Quote heath Quote  Post ReplyReply Direct Link To This Post Posted: May-06-2010 at 1:48pm
That could be the case.. Mine is retractable though.. It goes into the deck at an angle that causes it to come out just forward of the fuel tank.. I have already found two of the jetson style online.. One is 700 bones!! and the other $350.. little more than I wanted to spend on a stern light.. I bid on an "all around" style on ebay for 15 dollars.. It retracts like the one I currently have.. Guess it will do until i find a reasonable deal on the correct jetson style.. Thanks again for your help..
'cuda
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-06-2010 at 1:39pm
Heath,
I highly suspect a PO changed out your aft all around nav light!! Since your Cuda is a SS, then chances are good that it did come from the factory with the "Jetson" light. I did need a "Jetson" for a my Dunphy X55 since they too used the same light. After months of ebay searching, I did find one however it happened to be the non removable retracting into the deck type plus it was a short shaft outboard style. (we can't use retracting because our gas tanks are below the aft light) I ended up having to make a new shaft and modify it as well as the base for the plug/receptacle. Work but at least it's got the original back on it.
I mentioned the Perko Freznel. It too was used back then on the "better" CC models. Other models used the cheaper aft all around with the translucent white lens. The all metal Perko may be a good alternate. All metal Perko
Post Options Post Options   Thanks (0) Thanks(0)   Quote heath Quote  Post ReplyReply Direct Link To This Post Posted: May-06-2010 at 1:20pm
look closely here.. best I can do for now.. anybody else have this same light??
'cuda
Post Options Post Options   Thanks (0) Thanks(0)   Quote heath Quote  Post ReplyReply Direct Link To This Post Posted: May-06-2010 at 12:50pm
thats not the one I have then.. could possibly try making some type of mold and pouring one??? may sound a little crazy but I don't want to put anything on this boat thats not original.. Again, your help/suggestions are greatly appreciated!
Also.. Saw a guy that was selling the white step pads on here a couple of months ago.. I emailed him but did not get a response.. Know anywhere else I can get these??
heath
'cuda
Post Options Post Options   Thanks (0) Thanks(0)   Quote Riley Quote  Post ReplyReply Direct Link To This Post Posted: May-06-2010 at 12:46pm
This is the jetson style.
Post Options Post Options   Thanks (0) Thanks(0)   Quote heath Quote  Post ReplyReply Direct Link To This Post Posted: May-06-2010 at 12:38pm
Mine has the same shape/ configuration of the the one in the picture below... (just the top part).. obviously the shaft on this thing is messed up.. But I need the lense thats in the shape of that thing..
I may be sol on this thing..
'cuda
Post Options Post Options   Thanks (0) Thanks(0)   Quote heath Quote  Post ReplyReply Direct Link To This Post Posted: May-06-2010 at 11:54am
"jetson style" sounds like a really good way to describe it.. did some searches on ebay but had no luck.. Oh well.. guess I'll keep my eyes open for one.. Def willing to pay top dollar for an original pylon if anyone has one.. Thanks for your help!
Heath
'cuda
Post Options Post Options   Thanks (0) Thanks(0)   Quote Riley Quote  Post ReplyReply Direct Link To This Post Posted: May-06-2010 at 11:41am
Heath, I beleive your boat would have had the Jetson style. They come up pretty regularly on ebay, but fetch a pretty high price if they are in good condition.
Original ski pylons and clearence bars are hard to find.
Post Options Post Options   Thanks (0) Thanks(0)   Quote heath Quote  Post ReplyReply Direct Link To This Post Posted: May-06-2010 at 11:25am
Thanks for your help.. I have looked everywhere for that lens and have not been able to find anyone who carries it.. I did a search for the perko fresnel, but still was unsuccessful.. Are we talking about the same lens?. Perhaps there were several that were offered? Mine has a square or rectangular shape when looking at it from above.. I did however find the source for the bow light lens should I ever need one..
Thanks..
Oh and for the rope guard, I think I may have a guy make me one out of stainless (same guy that made the ski pylon that is currently in my boat (made from a solid piece of stainless). Anybody know where I can find an original pylon??
Heath
'cuda
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-06-2010 at 10:04am
Heath,
The stern lens is available. You should have the Freznel Perko lens. Do a search on line for sources or your local marine supply. If by chance you have the "jetson" style, then you'll have a hard time finding a lens. Your best bet would be to kepp looking on ebay for a complete light.
The rope gaurd is made from 1/2 oval rub rail. Somewhere there's dimentions on site that someone posted. I'll see if I can do a search and find the thread.
EDIT: I keep getting "time outs" when doing a search. It's probably due to this old very slow computer here at work. Do a search using the key words like "rope gaurd" and click "older than 6 months".
Post Options Post Options   Thanks (0) Thanks(0)   Quote heath Quote  Post ReplyReply Direct Link To This Post Posted: May-06-2010 at 2:46am
Looking for a stern light lens (original) for my 66 barracuda ss.. (broken by a ski rope).. also would like to have the "guard" that keeps the ski rope off of the stern light and rear lifting ring.. anybody have anything of the sort??
'cuda
