Carpet adhesive? |
Post Reply | Page 12> |
Author | ||
srbranum
Senior Member Joined: March-06-2010 Location: Huntsville, Al Status: Offline Points: 376 |
Posted: May-31-2010 at 1:58am |
Put carpetting on the sides this afternoon and used 3/4 of a gallon. Still have to do the floor. Don't see anyway I could have done it all with one gallon. Maybe I used too much. Just my .02cents worth as they say. scott |
I have to keep her running 'cause I can't afford a new one
Dave, I don't understand who you're upset with. I re read the thread and to me it seems everyone is trying to help and give advice. The only difference is some use a contact adhesive while others outdoor carpet adhesive. You being a upholsterer I'm sure are more used to the contact adhesive. Personally, I feel the carpet adhesive is prefered due to the fact you can make minor adjustments. keep in mind we are laying carpet and not vinyl over foam. BTW, they must have made some changes in the contact adhesives. A few years back, I worked on the problem of using a 5 gal pressure feed to a atomizing gun for contact adhesive. I worked with Binks, gave up and went to DeVillbiss and still couldn't get it to spray properly. Lots of fluid tip combinations and even worked with the contact adhesive manufacturer. You're very lucky you can get it to work properly out of the cheapest gun available - the Harbor Freight Chinese import!!! |
LAKESIDE
Senior Member Joined: May-14-2010 Location: Jacksonville FL Status: Offline Points: 160 |
I thought this site was for advice to help others with there projects? Maybe i was wrong. Well it's you boat your the only one who has to like the finished job, so what ever floats your boat. Good luck with you carpet.
DAVE |
93 Ski Nautique SUCK MY WAKE
horkn
I have not done that much carpet work with the 3m adhesive, but I know it held the carpet in perfectly on my brother's 86 jeep cj7 we frame on resto'd, and I have used it on countless speaker boxes, and in my nautique with no issues. My friends who helped a lot with my upholstery on my boat owns an upholstery shop and have been using 3m stuff for the 30+ years they have been in business. |
79nautique
you have to pay attention to the size of the grooves on the trowl for that quoted coverage area, and then compare that to the size required for the actual carpet you are using, I bet it's much smaller thus the area of coverage goes up, Not like you can't go to the store and get more if you run out, but I think you'll be taking some back anyway.
srbranum
Harddock,
Disregard any post you may see from me on concerning Lakeside's comments. I am sleepy from working last night and did not know what I was doing. Have a Blessed Day, Scott |
srbranum
Maybe I bought way too much but I have only put carpet in two boats in my life: one about 35 years ago and this boat about 15 years ago and I don't have a clue how much I used either time. The one gallon bucket says 60-90 sq. ft.coverage. My boat is about 14' long counting the area up under the dash and 8'-9' wide counting the floor and both gunwails. Take out the small amount of space for the engine and I come up with about 110sq. ft which is more carpet than the one gallon bucket said was sufficient. I would rather have too much than pinch pennies at this point especially after spending $2500 on the project. Just my .02 cents worth. scott |
harddock
Platinum Member Joined: June-04-2008 Location: Toontown, MA Status: Offline Points: 1763 |
I wonder why you've had such bad luck. I've been putting down carpet since I was 15 (I'm 54) owned a carpet store for 20 years and have done boats, cars, trailers, docks, etc and had as good of luck with 3M as with any carpet specific trowled of stuff. I followed the instructions and never had issues. I've got carpet on an aluminum dock that gets wet, gets hot and even stays out in the snow for more tha a few seasons. Held on with 3M/ Go figure! |
79nautique
so how many boats do you plan on carpetting? I'll be suprized if you use a half gallon on a 16 footer now if you going for the adhesive through the carpet look then ok.
srbranum
Pete,
Picked up two gallons of Henry's 263 today from a company called BPI(Building Products Inc, I think). $39 total. I returned the Henry's stuff I had bought at Lowe's for about $32 so I only paid about $8 more for this stuff. Thanks, scott |
srbranum
Going to buy this tomorrow morning when I get off work. Come to find out it is only two miles from where I work. Thanks scott |
LAKESIDE
Home depot sells this. Much cheaper than the spray stuff. This will be more than you need.
DAP 128 Fl. Oz. (Gal.) Weldwood Original Contact Cement Model # 00273 Store SKU # 465631 $29.98/EA-Each Description A multi-purpose neoprene rubber adhesive that forms an instant, high strength bond on a variety of surfaces. Offers hundreds of uses for the home, office and workshop. Forms strong bonds on contact to eliminate the need for clamps, temporary fasteners and long set times. Ideal for bonding: plastic laminate for counters and tabletops, wood and plastic veneers, metal, wood, leather, linoleum, tile, rubber, cork, polyurethane foam, paper and cardboard, many plastics and vinyls and other porous and non-porous materials. Resists the effects of heat, water, weather, grease, oil, and household chemicals. America's best selling contact adhesive. For interior and exterior uses. * Strong, Instant Bonds on Contact * Can be Used on a Variety of Surfaces * Excellent Water Resistance * Interior/Exterior * MFG Brand Name : DAP * MFG Model # : 00273 * MFG Part # : 7079800273 |
LAKESIDE
Been doing upholstery for 23 years.The spray adhesive is crap. Even 3m. I would never recommend using that. Doesn't hold up after heat hits it. If you have access to a pray paint gun and a compressor, try to find some straight up contact cement. It sprays great out of a gun. Home depot sells it in gallon pails. Or maybe if you have a local upholstery shop you can buy some from them .We sell it all the time to customers. WE buy it by the 55 gallon drums. Also when applying it make sure you put glue on the carpet as well as what you are gluing it to. Let dry for a few minutes the stick it down. You wont have any problems. If you don't have a way to spray it you can always brush it on. Harbor Freight sell spray guns for around 15 to 20 dollars. Been using them for years.
srbranum
I just bought the best marine carpet they had from Lowe's. Woody at Mastercraft of orlando(formerly Southeast CC) told me that's where he would buy it if it were him. My contact told me about the 2" deal. He said that much would allow for it to even out instead of bucking up with a shorter amount.
I only use the boat 12-20 hours/summer so I just could not justify the Overton's or other expensive stuff. |
horkn
I didn't overlap that much. It would have been lumpy had I done it that way.
What carpeting are you using? I used marine carpeting that have a tad more thickness than the stuff that nautiques have. |
srbranum
Thanks,
This is how I was told to do it: Cut the sides first. Come down the side and on to the floor 2" back to front. Then put the floor down and come up over the 2" from the side to flush with the gunwail. Seal the edge with liguid nails. I asked my contact about the overlap down the side and would it be a hump or look bad and he said that's how they do it from the factory so unless I hear otherwise, that's what I'm going with. scott |
horkn
Take your time, measure twice, and cut once or it will take longer and cost more;) It took me a few hours to get mine re carpeted after I replaced the flooring. |
srbranum
I bought some of the High Strength 3M spray adhesive at Auto Zone today($20/can X 3 or 4 cans ) but I found two places locally that sells the Henry's 223(?) Pete was talking about so I may check it out monday.
Question: How long should I allow to install carpet in my 16' CC Skiier? |
horkn
I used the 3M spray adhesive as it worked great on my martinique. It holds great even after several years.
inglesideshawn
Senior Member Joined: April-03-2009 Location: ingleside, il Status: Offline Points: 203 |
cements quicker and easier just fold and roll the glue out.. trowl down can be moved and adjusted but takes twice as long.. made patters out of paper then cut big to alow for triming
1989 nautique
JoeinNY
I was more in the 6 x 40 range with the extra's that needed to be covered in a 18 foot long boat, but my 83 being a hobby boat doesn't exactly have a "intelligent" or even "realistic" budget. It was 40 oz marine carpeting.. not something I would recommend... |
srbranum
Wow! Did I buy the wrong stuff at Lowe's? I only spent about $150 for a 6'X 28'piece to cover everything. |
TX Foilhead
I used the can, I was doing things that were small at first and trimming off the extra. Worked well, so I used it o. The sides. If you have large pieces where you don't have much extra you could run into a situation like Pete was talking about where you can't move it around. I got the carpet at Lowes and it was cheap enough to where it didn't matter that I wasted a bit.
Wacko
Senior Member Joined: March-21-2009 Location: BC, Canada Status: Offline Points: 293 |
Are you using a spray adhesive or is it a can that you are spreading on? I did see some 3M Super 77 in a spray adhesive at the local hardware store.
harddock
3M Supertrim Adhesive. I've used it (successfully) for years. I have a piece of the Lowes indoor/outdoor carpet that looks like corduroy on an aluminum dock which stays outdoors through snow and sun and rain and it is still stickin.
You can adjust the spray pattern and do small areas if needed or large areas. You are allowed some reposition time too. |
Shawn,
Got it now!!! The carpet adhesive will stick to epoxy. The contact cement you used sure will too except it doesn't give you any opportunity to move a misplaced carpet. Did you have help? Usually you need about 20 arms and hands with contact cement!! |
inglesideshawn
my boats epoxy over 4lb foam,afer the stinger job.. that would be epoxy as in the floor..not sure if trowl down glue would even stick to exoxy,if that makes sence..
1989 nautique
Shawn, Do you know someone that's tried to use epoxy??? Wow!! Did you try it? I would think the cure time would be a real problem. |
inglesideshawn
contact adhesive from weldwood adhesives is the best product ive used,two years and still holding over epoxy...
1989 nautique
RainDog
Platinum Member Joined: February-21-2007 Location: Mke/Grn Lake WI Status: Offline Points: 1387 |
I found the Henry 263 at our local Farm and Barn type store (Fleet Farm, (not Farm and Fleet) for us 'Sconnie boys). Try Tractor Supply or something similar. Lowes does not carry the 263.
