Wiring harness |
tutor turtle
Groupie Joined: April-17-2007 Location: United States Status: Offline Points: 50 |
Posted: May-25-2010 at 3:45pm |
That is certainly is the surest solution.
I was thinking along the same lines, my only reservation to that solution is: Can you think of any instance where I would need the "modularity" of being able to separate the harness? The only thing I could think of was, If I had to remove the motor (a very unlikely event) in which case I would ether label the individual wires, or disconnect them at their source/destination. What gauge are those conductors? I'll have to gather my stock before I leave home, the boat lives two hours north, up in Gods country, where the few stores that do exist, have little useful stock for ski-boats. Am I missing anything? I have a friend who works for Chrysler. They employed a Hall-Effect sensor for the throttle position, whose output was in the micro-volt range. No matter how clean the connector looked, it only took a little resistance to alter the reading and cause drivability issues. The TSB (technical service bulletin) specified: snip off the connector, solder the wires. It worked every time. Much Thanks- Steven M |
Tutor turtle
pmt2234
Groupie Joined: June-14-2005 Location: United States Status: Offline Points: 46 |
I fought the same problem for years, voltage drop at the plug/socket. I went cheap for a while, cleaning contacts, etc., then bought a bunch of proper marine grade wire and did everything point to point about 2 years ago. No problems since.
tutor turtle
Thanks brainard, I figured someone had to have seen this before and had a low-cost solution.
I've cleaned the male contacts, but the sockets are gunked-up and (as the previous poster noted) a little over-expanded. It looks as much of a poor grip issue as a corrosion one. But it's nice to know it's fixable. This should do the trick, thanks again. |
Tutor turtle
Steven,
To avoid you having to go through the whole thread, I just copied and pasted the following from a recent post. "Post Options Post Reply Quote 8122pbrainard Edit Post Quote Reply Posted: 13-May-2010 at 10:52am Originally posted by grose no power to the dash problem fixed. after a lot of testing, all it took was unplugging the wiring harness on the back of the engine an plugging it back in. just a loose connection. unplugged again and took a small screwdriver into the female end and closed them up just a little to get a tighter fit and we're good to go. Greg, I highly recommend to go after this connector again in fact, any connectors and terminals. The last one I opened up was on my Tique due to a voltage drop issue. I found nothing but green (copper oxide) inside. By cleaning all the plugs and the connections up, I eliminated 1.3 volts of power drop. Get inside each female socket with some "scotch brite" rolled up or use a small wire brush on a Dremel tool until all the corrosion is gone. Then and very important is to use dielectric grease when you put them back together. I have seen these plugs literally burnt up due to corrosion/resistance and the resulting heat." |
tutor turtle
On my 1983 2001, the 8-way engine harness plug appears to be getting flakey. I am seeing a 2 to 3 volt difference between the battery level and everything after this connector, including the ignition and dashboard.
If I cycle the connection, I can get everything working for a while. It looks to be a major project to replace the whole wiring harness, is there anything that can bring the contacts back to life? |
Tutor turtle
