Replacing a bilge pump |
Swatkinz
Platinum Member Joined: December-03-2003 Location: Lexington, SC Status: Offline Points: 1307 |
Posted: May-23-2010 at 5:47pm |
I got it working. As I mentioned, I originally had a 4 wire set up. There were 2 black wires to the switch and then a black and brown to the pump. The new 3 wire I hooked up only had one black wire (ground). When hooked up and working properly, I had a black wire left over. My solution was to tape it up out of the way. Probably not the way some would've done it, but it works and the install looks neat.
Steve
2011 Sport/Air 200 Excalibur 343 2017 Boatmate Tandem Axle Trailer Former CC owner (77, 80, 95, 88, all SNs) Former Malibu owner (07, 09) |
OverMyHead
Grand Poobah Joined: March-14-2008 Location: MN Status: Offline Points: 4861 |
A three way switch is essentialy the same as two singles. The pump should have two hot leads, one for manual mode and one for automatic along with a neutral. Hook up accordingly. The pumps mount is likely all plastic and easily drilled. See if you can template the holes from the old pump onto the new one, or fill and re-drill.
1987 Ski Nautique |
bkhallpass
On my 82, the bildge mount is a 1/2 inch piece of plywood covered with a couple of layers of glass. I'm not much good at wiring, but I would have guessed as you did - both grounds to one wire. BKH
Livin' the Dream
srbranum
Senior Member Joined: March-06-2010 Location: Huntsville, Al Status: Offline Points: 376 |
Steve,
See my posts on this same subject which I have been working on all day. It should not be that hard but it is stumping me. I had it all working before my stringer rebuild and now I am lost. Don't worry about the old holes in the floor. My pump is mounted on a small piece of glassed wood. Just fill in the old holes with a sealer and drill SHALLOW new ones Sorry I can't be much help. Pete and the others are trying to bail me out. scott |
I have to keep her running 'cause I can't afford a new one
Swatkinz
My bilge pump took a dump. The separate float switch was screwed up too so I'm replacing both. Each was wired separately to the separate switches on the dash. Purchased an Attwood pump this morning from Wally world that has the pump and float switch all in one. According to the wiring instructions, it's made to use with a single 3 way switch. Manual--off--Automatic. Can I wire this up to work with my existing separate dash switches? There are currently 2 wires going to the float switch and 2 wires going to the bilge pump. There are only 3 wires coming out of my new pump. I'm guessing that the single ground wire coming from the new pump will connect to both ground wires coming from the switches. and then each hot wire (one for the manual and the other for the auto) will connect to the hot wires from the switches. This should work right?
Also, the old pump and float switch were screwed into the hull. Is the hull thickened there (with glassed in plywood or something) to accomodate screws for pumps and such? I'm guessing that my mounting holes aren't going to line up and that I'm going to have to add some holes for this new pump. |
Steve
