  New Posts New Posts RSS Feed - lucas trans slip fluid
wakeboardin2k4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wakeboardin2k4 Quote  Post ReplyReply Direct Link To This Post Topic: lucas trans slip fluid
    Posted: May-23-2010 at 5:06pm
As usual, I am glad I posted before just doing.
Thanks guys!
"I'm planning to bring my girl that rides on a trailer with me and leave my girl that complains about camping at home"
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-23-2010 at 4:24pm
Eric,
You put that stuff in your trans and I guarantee you'll be sending out the trans to the other Eric in no time!! A marine trans isn't even close in design to the automotive automatic. The marine is simply a hydraulic pump that applies pressure to ether the forward or reverse wet clutch pack. As mentioned, you plates are warped.
BTW, Maybe you should put some in. At least a pint will do. Eric is slow and needs the work!!
Whitfield View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Whitfield Quote  Post ReplyReply Direct Link To This Post Posted: May-23-2010 at 4:17pm
I don't think Lucas will help...
I'm new here and may be off base ~ I am not a boat trans guy...
Most often I see threads stating boat trans slip is caused by warped clutch plates / poor friction surface. Lucas is not going to make warped clutch plates go away.
Michael ....
I'm the black sheep ~ 1984 Dixie 299 Super Skier (350 Chev PCM / counter rotation / Velvet drive) Open Bow.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wakeboardin2k4 Quote  Post ReplyReply Direct Link To This Post Posted: May-23-2010 at 3:11pm
Anyone ever use the lucas oil product to prevent and stop trans slippage?
Last summer when I upgraded to an HEI distributor and would hammer down on the throttle it felt like either my prop was slipping or my trans was slipping.
I also would think that the lucas oil stop slip would be a good addition for our transmissions because they work so hard.
Anyone see an issue with using this stuff? If so how much should I use. Our transmissions dont hold a ton of fluid and I want to make sure I use the correct amount.
