leaking airguide |
JERGY2.0
Newbie Joined: April-11-2009 Location: United States Status: Offline Points: 30 |
Posted: June-06-2010 at 10:55pm |
yea, I'll be able to do that........now that I understand what the problem is. THANKS for the info. Larry
Larry,
Yes, it comes up often with the older speedos. There's a metal bellows inside that convert the air pressure to a rack/pinion which then turns the needle. This bellows will fatigue and crack. The fix is to silver solder the crack. If you can't do this yourself, take it to a jeweler. Silver soldering is right up their alley!! |
JERGY2.0
I noticed the second time out this season that there is water coming from out of my speedo when we are under motion........any ideas as to what to do or how to fix
