  New Posts New Posts RSS Feed - Gauges and wiring
Gauges and wiring
boat dr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote boat dr Quote  Post ReplyReply Direct Link To This Post Topic: Gauges and wiring
    Posted: June-26-2010 at 1:55am
Karen at CorrectCraftParts has the same parts, we are now a PCM dealer...Give her a shot,
she will beat SkiDim or
the shipping is free.............Boat dr
Bremsen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bremsen Quote  Post ReplyReply Direct Link To This Post Posted: June-24-2010 at 2:12pm
Remind me never to cross Pete.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Riley Quote  Post ReplyReply Direct Link To This Post Posted: June-24-2010 at 1:01pm
Pete, why you got it in for Skidim?
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: June-24-2010 at 12:43pm
SkiDIM will have the PCM harness in an 18" pigtail (part number R121002). You'll need to cut it in the middle and build your harness up to full length with some proper marine grade wire.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-23-2010 at 10:43pm
The closest to original you'll find are Teleflex Vector series I put a set in my 77. Not too bad on price ether.
I shopped around and Go2marine was the best deal - better than Skidim Tim!!
junior View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote junior Quote  Post ReplyReply Direct Link To This Post Posted: June-23-2010 at 10:28pm
Boat is a 78 ski nautique. Close to original is fine, most of the gauges I have are no good. The speedos work though. The tach is 4" I believe and the rest are 2" or 2 1/16" a standard small gauge
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-23-2010 at 10:04pm
Alex,
How old? Original or close to?
Post Options Post Options   Thanks (0) Thanks(0)   Quote junior Quote  Post ReplyReply Direct Link To This Post Posted: June-23-2010 at 6:22pm
Looking for a tach, temp gauge, ammeter, and fuel gauge from an older nautique. Also looking for the 8 prong wire that runs from the engine to the dash for a pcm 351. thanks
