  New Posts New Posts RSS Feed - push button fuse switch
malibud View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote malibud Quote  Post ReplyReply Direct Link To This Post Topic: push button fuse switch
    Posted: June-24-2010 at 12:49am
found them thanks I think I was looking at main breaker
Chris4x4gill2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris4x4gill2 Quote  Post ReplyReply Direct Link To This Post Posted: June-23-2010 at 8:25pm
if your talking about the dash swithces, I searched for a while with no luck to find them for less than $20 with no luck. you ca nfind them listed in some electrical supply catolgs but their minimum buy quantities make it unfeasible.
Rglover View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rglover Quote  Post ReplyReply Direct Link To This Post Posted: June-23-2010 at 7:26pm
Originally posted by malibud malibud wrote:
I saw you can buy them at skidim for 50$ a piece is there anywhere to find them cheaper ?
You may have mis typed this, but they are only 19.58 at SKIDIM. Plus, you can still use the CCFAN code at check out and get 10% off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote malibud Quote  Post ReplyReply Direct Link To This Post Posted: June-23-2010 at 6:38pm
The fuse switches on my 85 ' 2001 keep going out I saw you can buy them at skidim for 50$ a piece anyone know if you can rebuild them or is there anywhere to find them cheaper ?
