draining trans fluid |
thatdude596
Senior Member Joined: March-28-2010 Status: Offline Points: 155 |
Posted: July-14-2010 at 8:08pm |
ski dim sells the pela extractor for 50.00 its a really nice pump, works well.
FrankT
Senior Member Joined: September-07-2006 Status: Offline Points: 245 |
I made a changer out of an old drywall bucket and a geared fuel pump. Use it for both engine oil and transmission fluid.
FrankT |
Tim D
This is what I use.
Tim D
martin 74
Senior Member Joined: January-02-2005 Status: Offline Points: 136 |
Got it.
Thank You Rich |
Rich,
Suck it out of the dipstick hole. Then no hoses need to come off. You won't get all of it this way but it's enough to get the job done. You can even use a cosmetic pump say off the top of a hand cream bottle. |
martin 74
So I remove the top hose and suck out of top instead of removing the lower hose and draining out of the bottom. Great!
Thanks Rich |
It's sucked out.
martin 74
Is there any shallow pan that is especially good for draining the 1.8 quarts of trans fluid into for my '74 trans change? I'm trying to do a neater job this time and keep the bulge clean. Any way to use my oil sucker?
Thanks Rich |
