  New Posts New Posts RSS Feed - ignition key or shifter
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Topic: ignition key or shifter
    Posted: July-18-2010 at 5:08pm
Originally posted by eric lavine eric lavine wrote:
since all the big cheeses are at the reunion,
And we were missing one of the "big cheeses"!
Eric, What happened to you? I had to do the alignment clinic all by myself.
Your no show was disappointing.
eric lavine View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: July-16-2010 at 9:16pm
no, but we can get you thru it....since all the big cheeses are at the reunion, I'll fill in and try to help
RKKP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RKKP Quote  Post ReplyReply Direct Link To This Post Posted: July-16-2010 at 6:15pm
Thank you for the advice! is there a Youtube "How to" to adjust shifter cable?
oldman
RKKP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RKKP Quote  Post ReplyReply Direct Link To This Post Posted: July-16-2010 at 6:13pm
I'm not a mechanic but I'll look for those wires. Thank you
oldman
Hawktique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hawktique Quote  Post ReplyReply Direct Link To This Post Posted: July-16-2010 at 12:39pm
I see this is your first post. If you ever have any tranny associated questions, go straight to Eric. That's his full time job!
"A Veteran is someone who at one point in his life, wrote a blank check made payable to: 'The United States of America,' for an amount of 'up to, and including his life." Semper Fi
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: July-16-2010 at 10:24am
check your neutral safety switch on the transmission, it should have 2 white wires going to it, it needs to be detented to complete the circuit, make sure your linkage is adjusted correctly in order to not burn up the trans.
RKKP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RKKP Quote  Post ReplyReply Direct Link To This Post Posted: July-16-2010 at 2:46am
I have a 1993 Ski Nautique and just recently when I turn the ignition key the motor won't turn over. but when I wiggle the shifter back and forth is when the engine turns over. What do I need to do. Is it a loose shift cable or what? Please shed some light.
Regards,
"old man"
oldman
