1982 CC speedometer question |
tryan
Senior Member Joined: November-12-2003 Location: United States Status: Offline Points: 345 |
Posted: March-03-2004 at 1:48pm |
you can mount the plastic surface mount jobs inside the older style metal housing with a new barb fitting hole in the back section metal housing. it's a walk in the park.
sammy who? mastercrap what? have you tried to test just the speedo? |
chris
Guest |
i went with the great lakes skipper. i wish i could have surface mounted them but i guess an internal mount will have to work. were'nt the "sammy duval" editions originally on mastercrafts?
anyway, thanks for the advice. |
Tribal150
Senior Member Joined: December-24-2003 Location: United States Status: Offline Points: 137 |
If you can't find any buy 2 of the ones that great lake skipper sells on E-bay, and canabalize them for the internals. They are really nice, and the internals are the same except for the face.
Rob |
ScottZ
Platinum Member Joined: January-20-2004 Location: Clanton, AL Status: Offline Points: 1154 |
The 82 Nautique uses the surface mounted speedo, not the flush mount. I do not know who would offer that type for sale.
Lake Mitchell , AL 1984 Ski Nautique 1972 Skier |
tryan
great lakes skipper has a perpetual supply of them on ebay also. lisa was very nice when i placed my order.
edit. you should check yours with a bugger sucker or blow into it standing in front of a mirror. if the diaphram has failed around the edge, you might be able to fix it. there are a bunch of connections and alot of hose between the transom and the dash. i wonder where vince was hiding the secret stash? i bought three new ones a couple years ago for 20 bucks a pop from another supplier. |
Keith
Admin Group Owner / Operator of CorrectCraftFan.com Joined: October-20-2003 Location: Pepperell, MA Status: Offline Points: 1917 |
Skidim.com has a few AirGuides available again (AirGuide is out of business) - for $129.95
AIRGUIDE WHITE FACE ILLUMINATED -Keith |
Chris
Guest |
both of my speedometers need replacing. what company is the best to replace them with? i can't seem to find anything with the same 0-50 mph range. any suggestions? thanks.
