  New Posts New Posts RSS Feed - water leak in 96 sport nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Topic: water leak in 96 sport nautique
    Posted: August-06-2010 at 8:06pm
Seb,
Your English is fine as well as the spelling compared to Chris's!!
Sephmu View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sephmu Quote  Post ReplyReply Direct Link To This Post Posted: August-06-2010 at 7:45pm
Just messin with ya kap....and yes some on here have a tough time with words no doubt!!
6am?!!?!?! waaayyyy too early!
...had to go back and edit the typo I made while poking fun of others, instant karma??
kapla View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: August-06-2010 at 6:03pm
Originally posted by behindpropeller behindpropeller wrote:
Originally posted by Sephmu Sephmu wrote:
Kap your english keeps me laughing!
Tim...Why so, too loud?
Ski @ 6AM and don't want problems.
wow wish I could do that, but I have to drop the kids @ school at 8am so its kinda impossible to make it so early!!
and saturdays..i like to stay in bed a little longer....
<a href="">1992 ski nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: August-06-2010 at 6:00pm
is it that bad?
actually I type w/o looking and post..then I realize my typos..but as long they´re not huge I just leave them like that!!! I think you guys get the point anyway...
I´ve seen some members with some huge ortographic problems...
remeber english is my second language....
I speak spanish..comprende?
Post Options Post Options   Thanks (0) Thanks(0)   Quote behindpropeller Quote  Post ReplyReply Direct Link To This Post Posted: August-06-2010 at 5:52pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sephmu Quote  Post ReplyReply Direct Link To This Post Posted: August-06-2010 at 5:42pm
My old hull hugger muffler is getting rough around the edges too, y-pipin this winter no doubt!
Leftseat, forgot to comment on your question #4....the recomended repair is to find something of same inner diameter, modified two liter bottle maybe, and start from new after removing all the old brittle glass, using the modified bottle inside the remaining bit of tube to wrap the glass around, then remove when done. Mine wasn't too bad so i just straightened it out best i could and went to town on it! not the best looking but it works
Someone here repaired a muffler inlet a few months ago and took great pics....try searching "muffler repair" i believe that should do it
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: August-06-2010 at 5:19pm
Really? are you selling the boat or just sick of the louder noise?
The idea of going y or duals in always around my head...
Post Options Post Options   Thanks (0) Thanks(0)   Quote behindpropeller Quote  Post ReplyReply Direct Link To This Post Posted: August-06-2010 at 5:16pm
Actually going the opposite way and putting the muffler back in.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: August-06-2010 at 5:09pm
Originally posted by leftseat88 leftseat88 wrote:
Hey Guys,
I have another newbie question for you. I have a water leak coming out of the port side fiberglass exhaust tube. I think that is what it is called, but the part I am talkiing about is the area just below the large approximately 4 inch hose coming off the riser. That hose looks to be deformed as compared to the other side. When I bought the boat 2 weeks ago there was a very small leak coming from this area. Now I can see that there are two small cracks in the fiberglass tubes coming out from behind the bottom end of the hose. So my question is :
1. How should I fix it?
2. Is it something a normal person can fix?
3. What is the easiest/best way to get the hose off of the riser?
4. Should the exhaust tube be replace or the suspected damaged area be cut away and reglassed?
Sorry for the long post but I need a little help!
Leftset-
If you can hold off till october I might have two of those for sale.
Tim
you are you Y-pipe right???
Post Options Post Options   Thanks (0) Thanks(0)   Quote behindpropeller Quote  Post ReplyReply Direct Link To This Post Posted: August-06-2010 at 5:01pm
Hey Guys,
Leftset-
Tim
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sephmu Quote  Post ReplyReply Direct Link To This Post Posted: August-06-2010 at 4:55pm
SkiDim didn't have it....
But nautiqueparts.com did! +1 for those guys as always
Fiberglass Downtube
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sephmu Quote  Post ReplyReply Direct Link To This Post Posted: August-06-2010 at 4:48pm
Leftseat,
I did the exact same repair as you on my 97 sport this winter. Super easy. Be very careful removing the old hose tho, like these guys said, it'll be stuck good and the old fiberglass is brittle and likes to crush when being pryed on!
I used two layers of Bi-axial mat on the outside of the tube and one layer on the inside...overkill but it was my first experience with glass-work. It's a nice kinda repair to cut your teeth on because it's hidden under the hose and no-one can see your hack-job!!
The inside of my exhaust hose was destroyed, falling all apart so while at I chose to replace with new.
If you have trepedations about the repair, I believe SkiDim.com has the replacement tubes...but what fun is that?!
BuffaloBFN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuffaloBFN Quote  Post ReplyReply Direct Link To This Post Posted: August-05-2010 at 11:23am
You got me Tim...I was just 'fixing' my post.
1988 BFN-sold
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: August-05-2010 at 11:14am
Originally posted by BuffaloBFN BuffaloBFN wrote:
You'll want to replace any questionable hose with corrugated, wire reinforced, wet exhaust hose. This is below the water line and could sink the boat. Also, a crushed or crimped hose will restrict exhaust flow.
I dont agree 100% with this. For long, straight runs below the water line, reinforced hose is just fine- you only need corrugated if there are any bends. The newer boats dont have any radiuses to worry about. Furthermore, the short (<1') stretch between the risers and invertaflow is not below the waterline- so while its a good practice, its probably not necessary to replace with reinforced hose here- I dont think CC used it from the factory.
Of course, theres no harm in using the corrugated- but theres probably no benefit either, at least in this application.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BuffaloBFN Quote  Post ReplyReply Direct Link To This Post Posted: August-05-2010 at 10:58am
Yes, you can pull the hose w/o pulling the riser. Like Kap said, carefully loosen/pry the hose from the riser(it will be stuck good), and I like to also loosen the other end where it clamps to the through-hull fitting. This way you can pull the whole assembly in to the middle of the bilge and remove as one piece. That last part may not work depending on which boat you have, but others will assist.
Edit-the boat is in the title...duh.
1988 BFN-sold
leftseat88 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote leftseat88 Quote  Post ReplyReply Direct Link To This Post Posted: August-05-2010 at 2:41am
Thanks for the info. Will I be able to put a new hose on without taking off the riser or the exhaust tube? If I didn't make it clear I think that the exhaust tube is somehow crushed right under the hose clamps. Any idea how this might have happened? I will try to post pics this weekend.
Post Options Post Options   Thanks (0) Thanks(0)   Quote kapla Quote  Post ReplyReply Direct Link To This Post Posted: August-05-2010 at 1:57am
some pics would help to see the problem
1 yes it can be fix with epoxy resin and glass
2 yes you can do it and if you ha ve doubts people here can guido you through..
3 unscrew the lock ties pour some soapy water between the riser and the hose..then pry with a large flat screw driver..this is in case you want to reuse the hose....if not use a gringer and cut the hose....
4 depending on the damage the FB tube can be repaired
Post Options Post Options   Thanks (0) Thanks(0)   Quote leftseat88 Quote  Post ReplyReply Direct Link To This Post Posted: August-04-2010 at 8:57pm
Hey Guys,
