  New Posts New Posts RSS Feed - carpet for 89 2001
carpet for 89 2001
ryanowen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ryanowen Quote  Post ReplyReply Direct Link To This Post Topic: carpet for 89 2001
    Posted: August-05-2010 at 2:56pm
1. 12 yards will be more than enough for the bottom and sides
2. I put in a new floor, so not sure... maybe just poke around a bit.
3. sides first so you don't get glue on the bottom carpet
4. perfectfit.com worked for me, bayshore marine carpet, $260 shipped
5. not sure of the weight, but it is almost identical to the factory stuff
hunterdan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hunterdan Quote  Post ReplyReply Direct Link To This Post Posted: August-05-2010 at 12:50pm
Hello
I have been looking a some of the threads on this subject but I still have a few questions.
1) If I buy the 8 foot wide carpet, how many feet long of carpet will I need??
2) Once you remove all the seats etc...and put down the new carpet how do you locate the mounting holes for the reinstallation?? Or do you fill in the old holes while the carpet is up and just put new holes??
3) Do you start with the sides and then do the bottom, or the other way around??
4) What is a good source for this carpet??
5) What weight is recommended??
Thank you for the help!
Dan
